Bellhousing Cracked What to do???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Oct 9, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I got a new th350/NP203 combo for 150 bucks...
    The bellhousing is cracked off from the little aligning nob abovethe starter to the first bolt hole up... about three inches total... Is this fixable... can it be welded back on...
    Or did I just buy a piece of junk...
  2. LAZYMON
    LAZYMON 1/2 ton status Premium Member
    Jul 26, 2000
    235
    Lake Tahoe
    My bellhousing cracked also. If you search I asked this question with some good answers. Ended up buying a strong built Th350 and replacing it. Mine started as a small crack and by the time I replaced it the things was cracked from one end to the other, still ran though.
    Let The Sun Shine Down Upon My Face
    Topless 73
    <a target="_blank" href=http://coloradok5.com/gallery/On-The-Rocks>http://coloradok5.com/gallery/On-The-Rocks</a>
  3. reddog64
    Nov 9, 2000
    3,325
    Mine didnt crack in a too bad of a place though... I'm holding the piece that cracked off in my hand...
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    As long as you're okay with it, get someone that welds aluminum to weld it up for you. I think it'll work fine.
    Tim
  5. reddog64
    Nov 9, 2000
    3,325
    so it could be welded then right...
    If it dont work... it's all good...
    It's only what... 150 for a new/used one at the yards...
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,376
    E-town baby!
    Welding cast aluminum is very tricky. The material is brittle as you found out and it just soaks up the heat. This can lead to spiderwebbing and more cracking. I've welded cast aluminum and it is a beotch![​IMG]
    I would consult a reputable tranny shop and see what they thought of it. Myself I would be looking for another case.
    Rene
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, with the right equipment. I personlly wouldn't attempt it, I'd have a pro do it. Aluminum is funny like that.
    I hope you KNOW that tranny's good.
    Tim
  8. dyeager535
    26,979
    Call aluminum head repair shops. They are obviously pros and are comfortable welding it. I had a tranny pump welded up, no problems.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
