Bellhousing Question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Tommy, Nov 17, 2001.
  1. Tommy
    Tommy 1/2 ton status
    Feb 21, 2000
    260
    Alabama
    Would a cast iron be stronger than an aluminum? I'm putting a 465 behind my bigblock and the setup I bought has an aluminum. Just wondering.
    Drive it Like You Hate It!
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    That kind of depends, but iron is a bit more ductile than aluminum, so given the same physical dimensions and shape, the iron unit would be stronger (and bout 3 times as heavy).
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    i just picked up an aluminum bell from a 6.2 desiel engine on a 3/4 ton 4x4 pick up. if they use it on that it should be strong enough, but then again. i'll be puting it behind a 350.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  4. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    I'm going with a cast iron bell housing in my Jimmy, because I like the visibility and accessibility to the throwout fork and bearing. There was a time when throwout bearings had grease fittings, you don't see that anymore.
  5. jmeador74
    jmeador74 1/2 ton status
    Oct 31, 2001
    108
    Eatontown, NJ
    Tommy....
    I might be thinking about going to a Big Block after having saw your rig and having heard it fire up... what all did you have to change when you went from small to big?
    Move crossmember forward?
    New radiator?
    New Exhaust?
    Fuel Lines?
    All that kind of stuff... so I get an idea of what I am looking at.
    72 Chevy Blazer, 327, SM-465, NP 205, 4in lift, 35 in tires
    About to put in 400sbc, 700-R4
  6. Tommy
    Feb 21, 2000
    260
    Alabama
    I bolted mine right in to the SB mounts, the crossmember will have to be changed or like I did cut and weld the hump deeper for the BB oil pan. I did not have to move anything except the crossmember. This may not be the prper way, but it worked for me.
