BELLHOUSING SWAP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BTCRAWFORD, Dec 9, 2002.
  1. BTCRAWFORD
    BTCRAWFORD Registered Member
    Nov 20, 2002
    17
    PHOENIX, ARIZONA
    What year(s)of bellhousings can I swap onto my 80 blaze for a hydraulic clutch set up? It has the SM465 4-speed. /forums/images/graemlins/k5.gif
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    IIRC 86 - 91 (It might be 87 - 91).
    Have fun.
  3. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    I think it's 85 that was the first year for hydro clutch. Let's call it mid eighties to be safe./forums/images/graemlins/thumb.gif
    Rene
  4. BTCRAWFORD
    Nov 20, 2002
    17
    PHOENIX, ARIZONA
    Did you have 4-speed to start with?
  5. dyeager535
    26,975
    Actually I believe '85 was the first year of the hydraulic bellhousing, and at least up till '91 in 3+3, K5, Suburban, etc.
    Not sure about the say '88 C/K trucks, if they used an SM465 in any of them, I'm not sure how the clutch is set up. It may have been passenger side clutch fork, but might be worth investigating. The block bellhousing bolt pattern didn't change, nor did the SM465 bellhousing bolt pattern, so if an '88 C/K has an SM465, and the clutch fork is on the drivers side, it might work too.
    Only reason I mention the '88+ C/K's is that the '85+ hydraulic bellhousing are kind of rare to find. The later the year of the truck, the less likely it would be to have a manual transmission.
  6. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    I had the auto 350/203 to start with.
  7. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    dude just get a after market kit that will bolt to you current belhousing lots cheeper and easyer
  8. BTCRAWFORD
    Nov 20, 2002
    17
    PHOENIX, ARIZONA
    Who makes a complete after market kit?
    Will it bolt up to the existing clutch pedal?
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    nothing that works/fits as well is cheeper or easyer.
    a hydraulic throwout conversion from Tilton or McLeod would be cleaner but replacement is ugly as the tranny must be pulled.
    the factory stuff is real sweet
  10. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
