Bellhousing ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stus84, Jun 1, 2005.
  1. stus84
    stus84 1/2 ton status
    Mar 21, 2005
    109
    MN
    1984 K5 (SM465/208) the bellhousing on the tranny now is complete & seals up everything like a basketball cut in half - the bellhousing I had shipped to me the bottom is exposed (I thaught they were all the same) - the bolt pattern looks the same - can I use this new bellhousing my old one is cracked - is there a bottom piece I need to buy for the new one? Has anyone ran into this or do I need to post some pics?
  2. dyeager535
    26,982
    190
    Sounds like you are missing the cover. I believe there are two different ones, a search should net the last thread that covered this.
  3. stus84
    Mar 21, 2005
    109
    MN
    I found some good info however not all that I need - sounds like an inspection cover is what I dont have for the new bellhousing which the old bellhousing didnt have. Do you have any idea if it will still fit it must be from an older setup. It also sounds like this is going to be a bastard to take out and replace - i will be doing the clutch at the same time. It took me forever to get a bellhousing finaly I got one and i am missing part of it. hopefully it fits... I will try to post pics...
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Is your replacement bell cast iron ?
  5. stus84
    Mar 21, 2005
    109
    MN
