bellhousings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ruff_ryda_420, Jul 22, 2003.
  1. Ruff_ryda_420
    Ruff_ryda_420 Registered Member
    May 22, 2003
    19
    alberta
    i'm after a bellhousing for my SM465 that has a hydraulic clutch. 85 and newer '465s are setup in this way i belive, but could i get a bellhousing from anything else, a camaro maybe?
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    The 1982 and up Camaro's have a cocked bolt pattern and a smaller index bore. Most cars used a 4-11/16 bore while the trucks usually used a 5-1/8 . It looks like you will need to use a truck bell housing .HTH , Tom
  3. Ruff_ryda_420
    May 22, 2003
    19
    alberta
    okay then, second question, can a bellhousing that is meant for linkages be converted to a hydraulic slave?
  4. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    I don't think so but anything is possible . The hydraulic bellhousing has a two bolt( with a hole for the slave cyl. ) mounting surface casted into it and it looks like it would be VERY difficult to duplicate that with a fabricated bracket . It might be easier to just locate an actual hyd. bell housing instead of fabricating one . HTH , Tom
