benchtop grinder... HF?
Discussion in 'The Tool Shed' started by jekbrown, Aug 19, 2006.
  1. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    I'm in need of an el-cheapo benchtop grinder. Using a 4.5" handheld grinder for hours on end on small pieces is a real PITA. I'm headed to HF to see what they have. Anyone have a HF one? If so, which model and how do ya like it?
    j
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've got the "Industrial" 6" grinder, the yellow one. I bought it "on sale" and it's been a fairly good, if underpowered grinder. But I find my 4.5” grinder works faster for most things.
    If I ever get a round tuit, I have been gathering parts to build a belt driven grinder which I feel is vastly superior. This one will run a 2HP industrial GE motor driving a heavy ~1.5" diameter spindle running in Timken bearings with a coarse AO stone on one side, and a 3/4 Super chuck on the other. A second spindle will mount a fine AO and a fine SO wheel. And a third spindle will drive a 72" belt sander patterned on the KMG posted before. I’ve got most of the parts, and machines+stock for the rest, just got to get it done.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I have an 8" orange one. 3/4 HP. Its a little underpowered, but works fine for what I do.
  4. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    daily grind...
    I have a "Buffalo" brand 6" bench grinder--bought from a flea market many years ago...has no balls at all,you can stall it quite easily..I get by with it,but I would not buy another cheapie..it was only 20 bucks though..still works ok..
    My co-worker at the junkyard made his own,by robbing a motor from an old washing machine,that had a shaft on each end--had to weld a base on the motor...he found 2 "mandrels" at a hardware store for about 4 bucks apeice,to mount the grinding wheels to it with..it blew mine away,that thing would not bog down and stall like my grinder would!....(and it was built from JUNK!)..:doah:
    I had a simple 1/4 hp electric motor with a pulley/belt drive and a "poilishing head" bolted to a peice of 3/4" plywood for a grinder/wire brush combo for a long time (still have it!)--I think it was better than the Tiwan grinder is.....:crazy:
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I bought one of their little 4" wheel grinders, but I only use it for sharpening the TIG tungstens.
    For metal removal & shaping I prefer the 6x48 belt sander.
  6. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    got the HF el-cheapo. We'll see how it does. Only $24.50 brand new after I used my 15% off coupon. :)
    j
  7. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    used my HF quite a bit today. I can stall it if I try, but its a bazillion times better / easier than using a handheld for several hours at a time. ;) As always, I wish I had the coin for some supa-bling bling tools... but I'll make due with the HF stuff until the Powerball winnings start coming in. :thumb:
    j
  8. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    How many HP and how many amps does it draw? TIA.
  9. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
  10. cbbr
    Jul 17, 2004
    14,681
