bender and tube
Discussion in 'The Garage' started by shaun, Mar 4, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    So I want to build a cage and bumpers for the new pickup. What kinda of bender do I need and what size tube. I never thought Id do this stuff myself but now I want too. Any info and tips are needed and appreciated. I tried search but not getting what I need. /forums/images/graemlins/dunno.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Here's the short version of it:
    Most people make bumpers out of pipe. Most people make cages out of tubing.
    You can't bend the two different types using the same bender/dies because of the different ways they're measured (pipe is measure using ID, tubing OD).
    Essentially, you have to buy a tubing bender because I believe those have the dies available for bending pipe as well. There's also nothing that says you can't make a bumper out of tubing.
    That's just what I've picked up so far...I'm still a newbie in the world of pipe/tubing bending and look forward to reading any other responses/corrections to what I just said. /forums/images/graemlins/thumb.gif
  3. shaun
    Apr 22, 2003
    745
    thanks more info please. let all of us minor pions learn from those of you with the needed knowledge /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
    /forums/images/graemlins/waytogo.gif
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    you could also make bumpers out of square tubing rather than bending round tubing.
  5. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Umm, all my stuff is tubing. Pipe is for plumbing, not for truck parts... Bumpers I make are all 1.5" .120" wall tubing, cages. 1.75" .120" wall, etc. I use a Pro-Tools One-Shot Hydraulic Bender.
  6. shaun
    Apr 22, 2003
    745
    thanks jason. Where do you buy your tubing and bender?
  7. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Is that the hydro version of the 105 or is it one of the bigger ones? TIA.
  8. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    You might want to search on Pirate, lots of good info on this over there.
  9. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I buy my tubing locally at B&B Metal Supply. I bought the bender direct from Pro-Tools.
    This is mine:
  10. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I've got a JD2 converted to Hydro using Jay's setup as a guide.
    BIGJ
  11. shaun
    Apr 22, 2003
    745
    So if I bought the 15 ton one shot hydraulic bender.(595)
    I would also need either the Electric hydraulic pump or the air over hydraulic pump and a compressor to power it? If I am just bending 1.5" and 1.75" both by .120 then I will need two different die sets? Which would be better the electric pump or the air air/ and compressor? Thanks for all the answers. /forums/images/graemlins/waytogo.gif
  12. shaun
    Apr 22, 2003
    745
    I will look at pirate also.
  13. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I run the air over hydraulic cause it was cheaper and it works just fine. Yes you will need a compressor to run it. You will need one die for each size of tube, 1.5, 1.75, 2", etc.
  14. shaun
    Apr 22, 2003
    745
    What compressor do you run?
  15. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    An Ingersoll-Rand stationary vertical tank compressor.
  16. shaun
    Apr 22, 2003
    745
    What size is it? /forums/images/graemlins/thinking.gif
  17. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    5hp I think 50 gallon... I've ran my bender with a dinky little pancake style job site compressor and it worked fine. It doesn't require a whole lot of CFM.
  18. shaun
    Apr 22, 2003
    745
    Tha is what I was wondering. Any tips you can give me? /forums/images/graemlins/dunno.gif
