bending 1/2" plate steel?
Discussion in 'The Garage' started by yunit, Oct 10, 2003.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    bending 1/2\" plate steel?
    Anyone bending 1/2" plate steel??? I came up with a design for a new doubler crossmember /forums/images/graemlins/thumb.gif an it requires me bending 1/2" plate up to about a 45 degree angle. I might try and make my own press, but don't know what kind of pressing power I will need.
  2. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Re: bending 1/2\" plate steel?
    I'd say "SuperHuman" pressing power! /forums/images/graemlins/thumb.gif
    Seriously, it might be easier to do it in two pieces and get a nice 220V welder to fuse them together. An angle grinder and flapdisc will allow you to put a nice radius on the final part to make it "look" as if it was bent into shape.....
    Just an idea.
  3. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    It would take about a 20 ton press. You can weld V blocks out of 1" steel and sandwich a 1/2" steel plate between them.
  4. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    With heat I've done it with a 12 ton press. However, it's a lot of work. The metal shop where I'm from will bend metal up to 1/2" thick for $2/bend.
  5. Re: bending 1/2\" plate steel?
    BBFH /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/tongue.gif
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    A pirahna will bend 1/2" plate. Don't know how wide you are talking. We have an attachment that replaces the punch and die set to bend steel. I know we have done half inch on it. I think my friend made ubolt plates out of 1/2 and bent the ends upward on it.
  7. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I can do a 90 degree bend in 1/2" with my junk but only 2" wide... 3/8 up to 4" wide and 1/4 up to 8 etc.
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    20 ton press. . . or 12lbs sledge.
    a=f/m or f=ma so. . . .if you swing a 60N sledge (at the right spot) at 10m/s and it accelerates from 10ms to 0m/s in 0.005s that's 2000m/s/s x 60N=120,000N . . . or 12,000kilos, or a little over 24,000lbs. keep in mind those are all rough estimates and a 12lbs sledge will definitely bend 1/2 plate. . . slowly. however- i really just felt like doing physics. . . WHY?!?!!?
  9. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Damn, I knew I shouldn't have slept thru physics, now it's all coming back to get me /forums/images/graemlins/shocked.gif Thanks Dr. Bowtie, class dismissed /forums/images/graemlins/thumb.gif
  10. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    I need to be able to bend up to about a 2 foot section. /forums/images/graemlins/shocked.gif
  11. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I've bent 1/2" before...
    I used a torch...and a vise...
    If you heat-it-up enough...it will bend EASY!!! /forums/images/graemlins/smirk.gif
  12. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    1/2" steel requires 30 tons of force per 12" to bend. The V that you bend it into will have to be 8X the diameter, so that means it would be 4" wide. If you heat and bend you will lose a lot of the properties of the metal. Although 1/2" thick seams extreme. 5/16 would easily hold the weight of your vehicle with 3/8" leaving lots of margin. If you are going to use 1/2" cut and weld the angle you want into it. You will be able to make the radius much tighter, and your ears and back will thank you.
  13. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    May I ask, what are you building?
  14. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    ___________________________________
  15. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Doh!!!
  16. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    what exactly are you doing with the old one?
  17. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Scrap, once the new one is ready.
  18. shaggyk5
    1,610
    SE pennsylvania
    il ltake it off your hands for the 89 cents youd get at scrap steel prices....i dont have a doubler yet and wont for a while, but thatd save me some time later on....
