Bending steel brake lines?
Discussion in 'The Garage' started by dontoe, Feb 21, 2005.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    What'cha use to bend 'em without kinking 'em?
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I went to auto zone and got a tube bender, it was around $15.00.
  3. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    What he said. Just a little hand held tool.
  4. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I bend mine by hand. :grin:
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Get those tubing benders that look like springs. You just slip them over the tube, then bend it over your knee or whatever. A lot less fooling around, and less kinking in my experience.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive always bent them by hand, just go slow and you won't kink it.
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Now ya don't have to get personal!!!!!!!!!!!!!!!
    :rolleyes: :rolleyes: :rolleyes: :haha: :haha: :haha: :haha: :haha: :haha: :haha:
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Have to let that one go.....no need to get greedy!
    By the way guys............thanks.........I gotta go get some front Vega hoes in a few minutes and I'll stop in at Autozone............Thanks again!!!!!!
  9. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    its easy!!!(to kink em!)
    I use a pipe,tree,or a trailer ball to help make tight bends--I've also used an old pulley,by putting a bolt in the center hole and clamping it in a vise--the only lines that give me trouble are 3/8 steel tubing like gas lines,it kinks before it bends most of the time,even with a proper tool its difficult to bend without kinking it--the 5/16,1/4,and 3/16 lines are no problem,but the 3/8 is a PITA,especially if your trying to make a new line from the fuel pump to the carb(the one on a small block that runs behind the altenator,and comes close to the harmonic balancer)--but the other sizes are easy to bend....I've noticed they dont call it "Cant Kink" anymore on the packages--must have gotten sued for false advertising....:crazy:
  10. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Another great idea! Thanks.
  11. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    Yes my hand bender hardly gets a workout. I use broom sticks, round stock, pipe, fence or whatever works for the radius you are looking for.
    T.J.
  12. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Well, just got back from NAPA with a tubing bender...........$45.00 Phew!
    But it is a quality one(I hope). Thanks guys! By the way, they wanted $35.00 a piece for front brake lines for a mid '70's Vega. I'm gonna see if I can use the ones off the front of my '82 K-10 parts truck.
  13. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
    I had the spring type bender and my brake lines were preflared so it wouldn't slip over so I wrapped electric fence wire around the areas I wanted to bend and bent the line by hand. Worked better for tight bends than any other bender I've used. It is galvanized wire so I just left it in place, looks like the coils around some factory lines.
  14. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I use a bender too. It seems liek a cluster **** when you start, but after a while, youll get used to it and its a piece of cake!
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I've got a hand bender with dies and follower rollers, sort of like a smaller version of my big tube bender. Works fine as long as you can get it in there and makes approx 3/4" CLR bends.
  16. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    i have different benders including the springs... but...
    has anyone here ever tried the old sand trick? i've never done it myself, the idea of putting sand inside the line always made me nervous... but i had an old timer tell me about it like 20 yrs ago and it sounded like it would work as long as you cleaned it thoroughly after..... one of these days i'll have to try it on a scrap..
  17. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yea, that's whut I got at NAPA.
  18. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Are the lines for a Vega or a 14 bolt disk brake swap? I bought mine brake lines at O'Reilly's for $12.49 each for a '79 Chevette.
  19. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I have those for 3/16", 1/4", and 3/8" I need the 5/16" but don't yet have a big enough project to justify it.
    Wish cage sized tube benders had the "0", "R", "L", and degree marks on them. I might actually be able make bends that worked out then.
    A good trick for making really tight bends up next to the nut is to drill and tap the end of a small piece of bar stock. Screw the nut in tight and use the bar as a handle.
