Bending steel tube
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudstud, Dec 18, 2001.
  1. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Is this right? Bend everything up then make the mitered joints? Is there a trick to getting just the right angle to miter at?
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>http://communities.msn.com/OffroadK5s</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Over at the Pirate board there is a new tech article on tube bending.
    It is an excellant article and is real easy to understand.
    After reading that I realy want a tubing bender now.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  3. Grim-Reaper
    7,385
    Atlanta
    Same here. Tin bender really made it sound simple. I have seriously though about getting a bender. I want to full cage the Lady's 79 since the kids ride back there. Probably will not put front legs because of the clearence issue and that truck doesn't see trails anymore but would like it in case some Jack off hits her and the truck goes turtle.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  4. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Here ya go: <a target="_blank" href=http://www.pirate4x4.com/tech/bendin_tube/index.html>http://www.pirate4x4.com/tech/bendin_tube/index.html</a>
  5. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Thanks a lot!
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2>http://communities.msn.com/OffroadK5s6superliftand33s.msnw?albumlist=2</a>
