Bent 205 Output Shaft
Discussion in 'The Garage' started by RSNHELL, Apr 9, 2005.
  1. RSNHELL
    RSNHELL Registered Member
    Jan 17, 2005
    53
    SANTA ROSA,CA
    anybody seen or heard of it? I,m still chasing a driveline vibration,and am getting frustrated. I've rebuilt the tranny, changed tranny and engine mounts,put in new 14 bolt,rims/tires balanced,new 1350cv HAD rear driveshaft( which made vibration worse).new wheel bearings ,hubs/rotors.It didn't start doing this until after I converted from an auto to a manual.new shaft in tranny and new bearings in tranny and transfer case. Anything I've missed? Any help is appreciated,thanks.
  2. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Just a thought - Is your pilot bushing/bearing in good shape. It is possible that your input shaft is wobbling and your disc is clamped in an out of round/balance position and it is beating the driveline to death .
    Like I said just a thought ??? You seem to have looked at all the usual stuff.
    Good luck , Tom
  3. RSNHELL
    Jan 17, 2005
    53
    SANTA ROSA,CA
    I've had the tranny guy tear it apart twice. I don't know. I'm thinking about taking my new HAD driveshaft to a local driveshaft shop to double check the balance. You know how UPS is.,when I recieved it the box was destroyed. CEnterforce 2 clutch, pilot and bushing,resurfaced 168 flywheel,12' clutch,transfer case rebuilt( existing shaft)
  4. tarussell
    Dec 28, 2002
    1,354
    Bagdad , FL
    But what about the pilot bearing in the crank shaft ? Did you put one in when you swapped out the auto tranny for the manual one ?
    Tom
    Sorry , I just re-read your response and you stated that you did do the pilot bushing.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    As has been said, need to have a pilot bearing in the end of the crank and also did you readjust your driveline angle after installing the CV shaft? With a CV shaft the rear diff yoke needs to be pointing inline with the driveshaft if not you will get a bad vibe.
  6. RSNHELL
    Jan 17, 2005
    53
    SANTA ROSA,CA
    yeah , the rear pinion is pointed up toward the transfer case (set 2 degrees below for axle wrap). The guy that worked on my tranny owns NORCAL transmissions in Santa Rosa and specializes in 4x4s.. He runs the same set-up in his truck ,so I'm pretty sure he did it right.
  7. RSNHELL
    Jan 17, 2005
    53
    SANTA ROSA,CA
    I"m stumped.
