bent axle housing?
Discussion in 'The Garage' started by Jonny-K5, Apr 15, 2005.
  1. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    what the best method to measure axlehousing straightness? looks like my rear tires might be slightly bowed in at the top, not sure if this is an optical illusion or not. i'd like to measure it somehow to be sure. whats the most accurate way?
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Same way you checka frame for straightness Jon.... take measurements at the top of the diff to the flange and bottom of the diff to the flange.
    I think this may work, maybe not.
  3. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    Mine does that too, not sure why.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    worn ball joints/kingpins?
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    dont think so.
    why not put your tape from rim to rim, top and bottom?
  6. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    A four wheel alignment would let you know.
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Pull out the axle shafts and look through the tubes.
  8. Mad-Dog
    Mar 20, 2005
    548
    Ocklawaha,Fl
    rear axle jeremy , not the front....
  9. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    If it's a 10 bolt, wouldn't be surprised if it's shaped a little like a taco. Mine did that on 31's. Alignment shops, particularly Sears, you can get a free alignment check. When he's got it on the rack, ask him to show you what the rear camber is at. He'll tell you he can't set that, but you want to see it anyway. Negative camber on both sides = axle shaped like taco
  10. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    never knew sears gave free alignment checks. sounds like that would be the most accurate way to tell if its bent.thanks guys
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    at work we print sears's auto service checklists we got a big order from them recently and are setting up a machine for it.
    ive had a 7.5" 10 bolt axle have the tubes come loose from in the diff housing and it was bowing reallllll bad, the tubes were coming out, it stil drove but would grind the drums on the plates
    ive never seen it happen on an 8.5" but i guess it possible
    those weld plugs seem to work loose
    sound slike yours has done it
    id like to confirm it if so, cuz ive never seen it happen on an 8.5
    if it has happened then you wont be able to miss it, when you look at the axle, it wouls be plain as day that the center of axle assembly is bowing down due to loose tubes.,
    good luck
  12. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    i dont think thats the case on my truck. if you look at the axle itself it looks arrow straight. but stand back 20ft behind the truck and looks like either tire is bowed in a bit. i'll check closer tomorrow tho..
  13. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    That exactly how mine looks on my D70, weird.
  14. trogdor4x4
    trogdor4x4 Registered Member
    Dec 15, 2003
    37
    Spring, TX
    my front tires seem to be bowed out on the top more than the bottom, and I am seeing some wear on my tires.
  15. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well thats odd
    never seen that one happen on a GM truck
    hum,.
    interesting
    ball joint adjustments are waaaaaay off maybe ?? shims wrong ??
    hum,./
    wierd.,
  16. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    is there any good reason not to weld the tubes to the pumpkin?
  17. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    ya, the housing is castiron, tube are steel. they expand and contract at different rates, potentially caussing the welds to break. that why they are only plug welded in the first place
