bent axle housing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Doug M, Dec 6, 2002.
  1. Doug M
    Doug M Registered Member
    Nov 8, 2002
    39
    Houston
    Can a frame shop straighten a bent axle housing. Camber is off. Ive heard of possible corrections for this at the ball joints but is there also a spacer that can go between the steering knuckle and the spindle?
  2. You could probably pick up a 10bolt from a junkyard cheaper than you could to repair the one you have.
  3. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    There is a shim that can be installed between the spindle & knuckle. You should be able to get them at any good front end shop. I thought they were approx $20 ea. I did this a few years ago after moving a retaining wall with my truck & tweaking the axle a few degrees. Not sure of the limit of correction with these, but mine was noticeably leaning & this corrected it. As stated a frame shop can "un-bend" it, but it is major $$. Have an alignment shop check it & tell you the amount it is off & you can install the shim yourself. Then have the shop align the toe setting.
    Lonnie
  4. Doug M
    Nov 8, 2002
    39
    Houston
    Your replies are appreciated. I've lived with this pulling for the last 45k miles but it sure would be nice to not have to fight it all the time.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    One thing to remember here, if the housing is indeed bent, you don't want to just shim it, because the shaft would be rubing on the seals and soon you would have leaks.
    Eithe swap housings, or get another axle complete from the junk yard.
    Or maybe it's an excuse to upgrade to heavier axles.
    If you already have invested in parts in this one, get a housing and swap everything from this one.
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    might take to a big rig alignment shop. Buddy works at one and they bend the axles on semis to actually align them and said he could probably straighten one when a frined of ours had that problem.
  7. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    I would just replace it if I was you. My rear 14bff is bent and it leaks pretty bad. It doesn't bother me driving it and it hasn't hurt the bearing but I can't keep the seal from leaking.
