Bent Axleshaft Ears
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bherring, May 9, 2002.
  1. bherring
    bherring Registered Member
    Nov 2, 2000
    55
    VA,USA
    I bent some with a press so now the snaprings won't fit. Is there a way to widen the ears back to normal? They only bent about 1/16".
  2. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I did the same thing once. It happens with the older, frozen shafts and joints.
    I just used a grinder to grind the ears enough so they'd fit. I broke that shaft, but the shaft itself inside the diff, not the u-joint.
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    You should not trust that shaft anymore. I will bet money that if you do make the snap rings fit that in the very near future that axle will break right at the ears. I have a set for a D44 that was frozen and I was trying to remove the joints and also bent the ears so I just threw the axles away and now have a reason to buy the molly shafts.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I did that too.
    I had to grind like Red said.
    what have you got to lose?
  5. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    A porta power will straighten them out.
  6. RedDwarf
    May 9, 2001
    816
    Well, you would think so, but re-read my post.
    I broke the inner shaft, but the joint is still good
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    no it wont i tried
    I guess I may have chickened out.
    the grinder doesnt break an ear off like the porta power looked to do
  8. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    I did the same thing, just a minor tweak to the ears, not a serious deep bend. I put the ear on an anvil and smacked the thick part of the shaft yoke with a hammer, just did it a few times and it put it right back where it was. Worked like a champ, right up till the Ujoint blew on trail 9 and took the inner and outer shafts out again.
    LOL
    Depdog
