Bent D60 Perch
Discussion in 'The Garage' started by BigCountryx, Jul 7, 2005.
  1. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    The drivers side perch on my D60 is bent concave or cupped. Is this a common problem? When I removed the spring I noticed that the outside edges of the spring seemed to be the only places touching the perch. Where could I find a replacement perch that I could be certain is the right height to match the cast perch on the passenger side?
  2. highrlr
    highrlr 1/2 ton status
    Nov 29, 2004
    302
    Bismarck, ND
    I have the exact same problem with mine(as well as the back side of the perch being bent down). I have posted on here and on Pirate and have not come up with a factory replacement other than a dodge perch which is 2.25" wide compared to the chevy which is 2.5" wide but im sure it would work just fine. I also heard from a person on this site that you can just build your own out of a piece of 2.5"x2.5" square tubing with 1/4" wall thickness. Great lake offroad also makes perches that are made out of 1/4" steel, I dont think they are application specific and as far as I know you have to buy them in pairs but im sure it could be made to work?
  3. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    I figured a factory replacement would be hard to come by, I guess I'll make my own while I'm making the rears. I just wanted to buy the one for the D60 because it has to match an existing perch. If I was replacing both like on the 14 bolt it would be less af a concern. Thanks
