BENT Flywheel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by engdray, Jun 10, 2003.
  1. engdray
    engdray Registered Member
    Jan 29, 2003
    5
    Mechanicsville, VA
    Took the Jimmy in for a "strange" vibration. It felt like the torque converter gone bad. My flywheel is bent. How can this happen? Any thoughts?
  2. dyeager535
    26,975
    Don't know, my car had a bent *flexplate*.
    Anyways, it seems to be fairly "common" for GM's to have flexplate problems (bent or broken) but since I don't mess with lesser makes (hehe) I have no idea if it's an isolated GM problem.
  3. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    I had that trouble for quite a while on my truck before I finally figured it out. Many, many, mechanics over the years failed to solve it, either.
    I ended up replacing the flexplate. I've got a write-up on it here: Flexplate replacement
    Kevin
    /forums/images/graemlins/burb.gif
  4. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    /forums/images/graemlins/cool.gif Common problem!! Replace it and next time you pull your motor check it for cracks. I bet if its bent then its broke!! Good luck its really not hard to replace just time consuming.
