Bent frame/anyone in WA??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Dec 20, 2000.
  1. dyeager535
    26,982
    191
    Actually was on the forum a while back, but just jumped back in. First off wondering if anyone else lived in WA? Always looking for people to trade parts with : )
    Second, I was wondering if anyone had any other ideas than what I came up with to check for frame straightness. The truck (http://yeagerd.home.mindspring.com/index2.html) is cobbled together from trucks between 1974-1991. I bought the frame seperately from a guy who had just had it painted. Why someone would paint a known bent frame is the first reason I can think the problem is not the frame...but anyway, after putting a body on the frame, (body from a truck that was hit in the drivers fender) and running gear, and getting the truck to concrete, I noticed it sagging in the drivers rear. Measured the axle to frame clearance without shocks(only factor in height here is suspension)on both sides, 1/2" lower on the drivers side. It has 3/4 ton springs on it, which I bought without seeing them on a truck. They were my second suspect after bent frame. So I swapped them from one side to the other. Same problem, same side. I measured front axle on both sides, very little difference side to side, 1/8" or less. Frame has no visible dents, cracks, bulges, stretch marks, anything in the rear area.
    Bumper lines up to body no problem, all body panels and doors fit/close fine. I called some frame shops, they all told me that it sounds more like a suspension problem.
    Since the rearmost pieces that the rear springs hang off of (hangars?) might be off different vehicles, COULD they have different heights? Thats the only thing I haven't measured.
    My idea is to jack the truck up (by the body, not frame) in the rear on flat concrete until the tires were off the ground, then level the bed with a bubble. Once that is established level, measure frame to ground clearance on both sides. Sound like it would work?
    This perplexes me, because if it was frame, I would think I would have had a large gap in some of the body mounts, which I did not. They all bolted up solid, no problem. Even then, unless the body was bent (which it appears to not be, for 1/2" off, there should be some very obvious wrinkles or something I would think) the body SHOULD pull the frame straight. I know how flimsy the frame is, its the body thats the rigid piece.
    Sorry this is so long, but I wanted to get all the facts out I could. I think in all my measurements and such, I have eliminated all suspect areas, except spring hangars and frame! thanks for any ideas!
    Dorian
  2. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    Raymond, WA here
    25 miles from aberdeen
    50 miles from chehalis
    55 miles from astoria
    Theres No Replacement for Cubic Inches!
  3. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    yakima wa(south central wa) bout 1 hour from naches trails
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Have you checked the body mounts? If one of them is shot, then it would lean a lot to one side.
    90K5
  5. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    Curtis Wa here !!!
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Not WA, but OR........Gresham to be exact. Right outside Portland. Spend a good bit of time down at Ocean Park/Oysterville (near Long Beach).
    Lots of folks on here from the Pacific NW, from BC to Southern Oregon.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  7. dyeager535
    26,982
    191
    Re: anyone in WA??
    Anyone from the NW that goes to the wrecking yards a bunch, and checks on K5's being parted out, let me know, I got somethings I'm looking for : ) And the same goes for everyone else..I don't get to the 'yards as much as I would like anymore, but I do go once in awhile!
    Dorian
    My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
