Bent Frame Part II
Discussion in 'The Garage' started by supernaut, Oct 5, 2005.
  1. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    So i've put off the frame straightening thing as long as possible. I called a shop that does frame straightening and they were like "yeah, 1.5 hours to set it up, 2.5 hours or more to do the actual straightening."
    is frame straightening really such a labor intensive process? 1.5 hours to set it up?
    My other question: i had to pry the frame rails apart with my hi-lift jack to get the cross member back in place. is that a good way to leave it? should i unbolt it and drill new holes in the cross member? so it's not under strain?
    After the frame is straightened, is it advisable to weld in mending plates over the previously bent areas?
    here's the link to the thread with my original questions, it got longwinded.
    http://coloradok5.com/forums/showthread.php?t=144666
