bent hood
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Aug 25, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    hey ever since i reinstalled my hood, on my 76 blazer whenever i close it the hood bends and it looks really bad and all. does neone know wat cause this and how to fix it, i know lmc sells those extensions and i plan on buying those, is there anything else i can do though?
    thanks,
    phil
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    grease up those hinges real good, are you talking about those hood stiffiners when you say extensions, I have some on my hood and they work but if your hoods to far gone they wont fix it...
    <font color=blue> I'd rather have a bottle in front of me, than a frontal lobotomy!
  3. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    You might have the hinges adjusted to where they close too tight. The rear two bolts on both sides of the hood can adjust front to rear and up and down. I had mine too tight and when the hood was closed, there were two little dimples . I adjusted it and now it is fine.
    <a target="_blank" href=http://www.moabdadc22.alloffroad.com/>http://www.moabdadc22.alloffroad.com/</a>Real four wheelers don't need tools to remove body panels, paint, tail lights..etc.
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Check at the front where the front of your hood goes. The two rubber things at the front. Screw em and unscrew em. They adjust the hood a bit too!!
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    If it wasn't for bad luck I would have no luck at all!!
