Bent rim
Discussion in 'The Garage' started by MTBLAZER89, Jan 3, 2006.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Is this easily fixable? It isn't leaking at all, but I don't like it. Can I just take the tire of the rim, and hammer that lip back?
  2. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Depending how bad it is. It looks like that's a steel rim, if this is so yes you can pound it out. But you may crack or loosen your chrome around that area. If you put a large piece of leather down and then place the rim face down you can hammer it out. Don't forget to clean up the inside edge where the bead sits befor you re-mount the tire. Other options are use it as a spare. Make it into a bead lock rim, use as a spare, replace... Hope this helps.... If it's alum. you may want to check around your area about repairing it. Sometime they both will crack....
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah it's a steel wheel, and it will probably become my spare in due time, but for right now I would just like to straighten it. I know the chrome will probably flake off because it's kinda cracked already.
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    GFI then!
  5. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    A large adjustable wrench can be used to bend it back nicely without mucking it it much.(once the tire is off)...tire shops,and "Ken-tool" brand tools also have a special wide wrench made for exactly that purpose,and it works much easier and better than a big hammer..
