Besides drive shaft what needs to be different in a 14 bolt rear swap?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RyansRod, Nov 11, 2001.
  1. RyansRod
    RyansRod 1/2 ton status
    Jun 13, 2001
    118
    Bay area CA. USA
    I have an 84 K5. I'm thinking about doing a 14 bolt swap and want to know what needs to be changed. Is the breaking system compatible? I know the driveshaft needs to be different but anything else?
    Friends don't let friends drive fords
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    The driveshaft will be fine you just need a hybred U joint..I forget the # but do a search on it. Everythign else is a bolt in as long as the axle is 3/4 ton. depending on year parking brake brackets may need to be fabricated or purchaced
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    You can use your driveshaft, just use the napa u-joint 447 it converts 1/2 ton to 3/4 ton. If you get a 14 bolt from an 81 and later you can just bolt the e brake lines right up.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    the drive shaft will stay the same you will need to put in a new u joint,part #447 at napa. the braking part will depend on what backing plates you have on the 14ff
    <a target="_blank" href=http://coloradoK5.com/gallery/Pauls89K5>http://coloradoK5.com/gallery/Pauls89K5</a>
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Just the rear u joint. I have the conversion joint in mine and it is Napa part #447. Also the e brake will work if it is a Burban or 1 ton 14ff with the e brake cables that the passenger side crosses over the pumpkin to the driver side.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  6. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    Another thing you will need are new u bolts and the spring plates unless they're comming with the axle.
    <font color=red>Wheel hard or go home.</font color=red>
    <a target="_blank" href=http://community.webshots.com/user/bowtie1ton>MY K5</a>
  7. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I know someone is going to make fun of me for mentioning this but......don't forget about different rims.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  8. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    i'm thinking about doin the same thing this week but i've got a 91 and i'm putting a 4 lift on this week.......so will i be able to use the u-bolts that came with the kit? will a 14ff bolt right up on my 91?
    high
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    To put it in a 91 you will need the same stuff. Also if the axle comes from a 1 ton you need to move the spring pads and shock mounts.
  10. greg83k5
    greg83k5 1/2 ton status
    Nov 2, 2001
    230
    space sity houston, texas
    yes they'll work...... if you use a cutting torch to get them red-hot and re-radiused to compensate for the larger axletube... i had to do this 'cause my lift was for the 1/2 ton.... kinda tweaky, but it got the job done...
  11. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    whats the difference between a 14ff on a 34/ ton and a 14ff on a 1 ton.....does a 14ff look the same as a 14sf?
    high
  12. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    the diff is in the location of the spring perches.
    i blew my main seal.
    now my brain leaks
  13. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The ff will have hubs sticking through the center of the wheel and the sf won't.
  14. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    does any one make 15 inch 8 lug rims
    high
  15. Esteban86K5
    3,712
    Bakersfield, CA
    I got my 15" 8lug wheels locally for 280 installed. I know ToyBoxOffroad is running a special right now for 55 a piece.
  16. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    You can get 15" 8 lug rims from alot of places. I got mine from Summit Racing and they cost me just over $200 for 4 of them to my door.
  17. mudhog
    Nov 6, 2000
    17,899
    portland oregon
