Besides the obvious (axles) what differences in 1/2 vs. 3/4 T?
Discussion in '1936-Present Suburban' started by BurbinOR, Oct 7, 2002.
  1. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Is it simply the axles? /forums/images/graemlins/burb.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    axles and springs, thats pretty much it
  3. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    Not much else. I know the 1/2 tons sit lower stock. The trans could be a weak 350t and you would probably have smaller drive shafts if not U joints. It really depends on the set up it comes with. Even in 3/4 there are still differences. If you have the factory tow package on a 90's model you usually came with 4:10's and a turbo 400 , otherwise you would have the 700r4. Just depends on the truck. /forums/images/graemlins/burb.gif
  4. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    there's actually more to it then just the axles. the rear springs in a 3/4 ton are 56 inches long on all years but 73 and 74. 1/2 tons are only 52.
    Spring hangers are longer, to lift the truck a little higher off the ground, and give it better ground clearance then the 1/2 tons.
    generaly the 3/4 tons came with a TH400 tranny, instead of the TH350, but this isn't always the case... my K20 suburban came with a T350, as did my friend roberts. he had a C20 pickup with a Th350 under it too. truthfully, the only things that generaly got the TH400 were bigblocks, and super heavy duty trucks.
    thats all I can think of right now... probably more that I forgot,
    -Rich
  5. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Didn't they shitch the 1/2 tons to a 56" spring midway throught the 88 model year?
  6. FLASHLIGHT76
    Jun 20, 2002
    255
    OREGON
    You know it's a funny thing about that. Superlift tried to tell me that all subs had 52" set up reguardless. I kept trying to tell them that my 89 has 56inchers. I believe your right about the half tons having the 56 inchers as well. I know that the 93+ have them on the half tons. It gives the subs that nice cushy ride yet retains load ratings. My 95 1/2 is set up with the 56's /forums/images/graemlins/burb.gif
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    my 87 3/4 ton has an oil cooler on the engine, my 83 1/2 ton did not. Also, I've got an th400 as oppose to 700r4, and 1350 rear ujoints. /forums/images/graemlins/pimp1.gif
  8. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    [/ QUOTE ] same here on my 89, a th400 oil cooler and 1350s
  9. jimmy88
    jimmy88 1/2 ton status
    Feb 17, 2002
    351
    Detroit, MI area
    My 88 1/2 ton has the oil cooler, I think its just part of the towing package, prol the same for 3/4 tons.
  10. Ddragggon
    Apr 25, 2001
    2,657
    yeah, the oil cooler is strictly a part of the `Trailering Special' tow package. my 77 C20 had one, my 73 C10 had one, and my dads 91 S-10 trailering blazer has one. ( I attribute the almost 300,000 miles the engine has on it to the oil cooler too)
    -Rich
  11. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    My '90 3/4 ton doesn't have and oil cooler. I'm installing one this weekend though. Does anyone know if there's a difference between the piece that goes between the filter and the block for a 78 big block and one that would work for my Sub?
  12. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    In my opinion, '91 was the best year for the 3/4 tons...
    In addition to the axles and springs, my truck has the 4L80E, oil cooler, trans cooler and P/S cooler. A quick check of the RPO's say it is all from the factory. I suppose it is all a matter of how the truck was originally ordered.
    Every time I find out something new about my truck, I have to smile thinking of how bad I "stole" it from the previous owner!
  13. BurbinOR
    5,829
    Oregon
    That DOES sound like exactly what I want..............exactly.
    Do you know where a RPO code designator/translator is located on the web or wherever? I'll need it when I look at some Burbs..........thanks. /forums/images/graemlins/thumb.gif
  14. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    I found most of mine here. Scroll down on the page for links to the RPO families.
    Also, thirdgen.org has a decoder here.
  15. BurbinOR
    5,829
    Oregon
    Thanks ! /forums/images/graemlins/thumb.gif
  16. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    It's all bigger!
  17. muddysub
    Jun 23, 2001
    10,451
    489
    JAXTER... NICE SUBURBAN!! /forums/images/graemlins/shocked.gif /forums/images/graemlins/cool.gif
  18. Burbinator
    Sep 14, 2001
    898
    Tempe, Arizona
    No problem...
  19. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I've found a bunch of mine HERE
  20. Ddragggon
    Apr 25, 2001
    2,657
    well, just when I knew what I was talking about, my parts truck completely proves me wrong....
    my 73 C10 out in the middle of nowhere has 56 inch 9 leaf springs under it. I'd never seen them on a 1/2 ton vehicle before, but hey: first time for everything donchaknow.
