Best 110 welder?
Discussion in 'The Lounge' started by SubYuman, Dec 29, 2005.
  1. SubYuman
    SubYuman 1/2 ton status
    Oct 13, 2001
    246
    Edwards AFB, Ca
    I want to do a little welding and I have seen some that go up to 1/4" although I suppose I'd be using more like 1/8-3/16". Can anyone give me any ideas as to something that will work and be relatively cheap?!?
    ARC, MIG or Flux core wire.....
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Lincoln 135
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have a miller 135 and its done its duty for the light stuff. If your welding outside all the time you may want flux core, but that produces a lot of splatter which isn't eye candy. If you can penny up, using gas will produce better looking welds, and penetrate better??
    ARC is hard on thinner stuff, and harder *at least for me* to control. MIG is best as it is fast and is easy to learn.
    home depot should have a lincoln welder to suit your needs as I hear.
    good luck
  4. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I used to have Hobary 135, worked great for me. Exact same as Miller 135, without variable adjustment, just 1,2,3,4 positions.
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    well look who just graduated from noob academy...:laugh: Thats some real good informative stuff Steve, now bitch slap that mofo for teching the lounge...:haha: :bow: ;)
  6. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    110V ARC welder...Haaaaa!!
    I had a 50 amp 110V ARC welder once..a "Montgomery-Ward"!..it was a joke,unless you used their special rods,you could hardly strike and maintain an arc with it..I suffered putting floors in my 72 K5 with it,then sold it for 20 bucks at the swap meet I sometimes sold stuff at..I paid 50,felt like it was worth 10....:rolleyes: ..
    I've had 200V arc welders since,money WELL spent..you can crank most 220V arc welders down to 20-40 amps and actually weld with them,whereas the 110V ones usually just have an "on-off" switch,and cant burn thru a paper bag..so waste NO money on a 110v ARC welder..MIG welder,ehhhh..if your welding 3/16" or less..don't believe the ones that say they'll do 5/16" or 3/8" in one pass on 110V Migs.they lie!:crazy:
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    x2 :thumb:
  8. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    miller 135 or hobart brother units are good . i have hobart unit.
  9. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Clark Weld 130EN with argon, does a good job.
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yeah if you want a cheap good welder for home use get a Clarke. About $150 less than a Lincoln and works just about as good on steel IMO
    I have both a Lincoln SP135 and Clark 130 with gas really dont see a lot of diference between the two.
    Both will weld up to 1/4" steel no problem.
    Lincoln is a little better qualiy but not $150+ worth. It also has longer leads and will weld aluminium better. Cuz it feeds wire a little better. The Clarke takes a little playing with the spring tension to feed alu wire. But a MIG aint the best thing to weld Alu anyhow.
    My Clarke is about 10 years old and still works good.
    Clarke WeldersYou can get one cheaper without a gas regulator but I like to use gas when Mig welding if i can. Welds are cleaner and it is easier to weld thick stuff.
    But
    Inersheild wire works good and is pretty much squeeze the trigger and weld.
    I am not saying that Clarke the best by any means. There are better 110V welders. But if you are on a budget. For basic home use they will work nicely.
  11. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
  12. dogdaysunrise
    dogdaysunrise 1/2 ton status
    Jan 19, 2005
    2,719
    Winterpeg
    I am also very intrested in this. I am going to need to do alot of body work to my blazer and the ol Buzz Box may not be up to that task LOL..
  13. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    Im in a welding class, and am 99% sure i just learned that Flux core penetrates better.
  14. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    stay away from century welders all together... i made the mistake of buying a g?125 which sucks my left nut till it turns blue... the material has to be spotless and clean to get any good weld... if you have any, i mean any crap there will be a difficult time welding purty, if it holds...this was not a prob when i was using a miller 175.... and i know proper welding techniques with the mig.... now only if i could master gas welding and brazing....
  15. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I just talked to the guy at the welding store last week and he told me the difference betweent he Lincoln 135 and the Millermatic are basically that one is red and one is blue. The Lincoln in the kit form Home Depot is NOT a 135. Also, according to the dude at the welding shop, shame on me if I ever try ot weld anything safety related (tow hitch, cage, bumber) with ANY 110 welder. He said that they simply cannot produce the heat necesary for full penetration. I am just relaying the informaiton adn have no opinion ont eh matter....don't know enough to have an opinion. However, if I can figure out how to get 220 to the garage I'm gettign the Lincol 215.
  16. dogdaysunrise
    Jan 19, 2005
    2,719
    Winterpeg
    Is the garage attached or are you gonna have to run a line?
    If you have to run a line, i would say get a heavy gauge cable either burried or get your power company to run an ariel line to the garage from the house. Then put a sub panel in the garage to run the outlets and a new welder plug.
