best 20 bucks i ever spent...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yeild2me, Feb 11, 2001.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    man, i have had this vibration/grinding sound coming from the rear end when taking off from a stop since i bought my jimmy in 95...i have changed u joints several times and came to the conclusion that i just wasnt going away...then the other day i was messing around under neath it and noticed a lot of slop when i yanked the tailshaft of the t-case back and forth...upon further inspection, i saw that the tranny mount was totally wasted...i went down to autozone and for 20 bucks bought a new one. it went on in about 30 minutes, and now is as smooth on takeoff as ever before...it also got rid of a lot of vibration at hi-way speeds...definitely the best 20 bucks ever spent!!!!!
    AIRBORNE!!
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    My same exact fix cost $45.............urethane mounts from ORD. You're right, makes one heck of a difference over those spongy old ones............yuk.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    How hard is it to change? Mine looks pretty bad...
    90K5
  4. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    it was a cinch!! i put a small floor jack in the center of my spare tire and positioned it on the tail housing of the t-case.. i removed the 2 bolts from the mount to the cross member...i loosened the cross member bolts until just a few threads was holding it up...i removed the 2 bolts from the mount to the transmission and pulled it out.. the whole time the t-case was supported by the jack..depending on how bad yours is, you may have to remove the mount to crossmember bolts before you jack it up...while i was there and had the crossmember bolts loose, i lowered the t-case with the spacers....i swear it took about half an hour....
    AIRBORNE!!
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I don't know if this is common, but under hard acceleration, I get a lot of vibration at higher RPMs. Did this cure it by any chance? It seems like it would.
    90K5
  6. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    the way i figure it, upon hard acceleration, the torque from the d-shaft rotates the pinion upward (as we all know), now if the mount is bad, the t-case and everything goes up becuase of the force pushing against the tailshaft...what this does is increase the u-joint angles..i really cant beleive the difference this made!! one way i thought that this could be proven would be to lie on the ground NEXT to your truck and have a buddy put it on gear, hold the brake and give it gas in short little bursts...this way you could see the t-case moving up and down....bought the new one before i could have my wife jump in the cab and help.. i think this is also the reason i cant keep the output seal from leaking because the constant wear on the bushing from the slip yoke riding on it....
    AIRBORNE!!
