Best 35 spline hubs?
Discussion in 'The Garage' started by chvyhs, Apr 18, 2004.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I tried searching already.
    I just want to know which hubs are the best or the pros and cons of each before I buy mine.
    It's for my Suburban on 42's with a D60 and a doubler.
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I'd say Warn premiums if you want locking hubs
    I'd say those poly perfromance slugs if you just want drive flanges
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    With 42's I would use slugs if I could. What locker do you have in the front axle? If you run an ARB I would run slugs for sure. 35 splines hubs are known to be kinda weak. But it could be a convenient weak link in the front axle. /forums/images/graemlins/dunno.gif
    Harley
  4. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I have the warns, have had no problem so far, but would do poly perf slugs if i had to do it all over.
    im running the same drivetrain, but with about 1/3 the weight.
  5. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I had stock GM drive flanges re-splined from 30 to 35 splines. I have not seen anyone break one of these flanges. I wouldn't consider using lockouts on my Jeep, but it's not used on the road. A friend with the same setup broke the steering u-joint and stub, but the flange was fine. It's up to you where you'd like to have your "fuse". /forums/images/graemlins/grin.gif
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    IIRC fox broke a 35 spline warn hub took them back and got slugs. Breaking a 35 spline hub sucks. Driving a slugged and locked axle on the street sucks too. I think tera-flex (tera low) also makes a good 35 spline hub. Never seen one tested though.
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I had a hard time deciding between the Warn Premiums and those poly-performance slugs! I ended up buying the Warn's just b/c I will be driving my K5 on the street quite a bit and I have a Detroit for the front. I did buy 2 sets though b/c in my mind, that is gonna be the weakpoint in my D60.
    I have a buddy here in town that recently purchased a CNC machine for his shop and I may have him make me a slug for the warn lockouts out of some decent steel. /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif Not really sure yet. Once the D60 is together, I am gonna start saving up for a full set of Superior shafts at which point I think I will force myself to find an alternative to the Warn lock-outs
    Chris
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Broaching out factory spicer hubs works pretty well, evidently they're pretty tough, and looking at the guts, they have the meat to get it done. I've broken ujoints with the warn hubs but I know they're not super beefy. Point is that they don't just fall apart on the trail, you do get some use out of them. With superior shafts, I don't know what to do for a hub, the only thing that would come close is a modified spicer. Maybe you just pull the gears for long trips? That could be a big pain but it's better than expensive hub fuses.
    I actually prefer the warn drive gears, I like the separate plate retention method better than bolting the cap to the gear. I think the warns would be a little easier to set up with the right spacers to keep the spindle seals pulled in tight.
