best Aftermarket HEI dist?
Discussion in 'The Garage' started by Redfrog, May 9, 2002.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I need some opinions in the best aftermarket HEI dist
    It will be for a mild 350 that mainly is a daily driver.
    Or would I be better off sticking with a factory unit?
    So lets hear some opinions /forums/images/icons/smile.gif
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I plan on getting the MSD HEI dist.
  3. Redfrog
    May 4, 2001
    753
    IL
    Thats what I am thinking but just want some opinions before I do. I am also thinking about the offroad box...
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Alot of people are running them, and most say it's better then stock. I'll have to see for myself here in the near future.
  5. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    a lot of my customers and fellow off roaders swear by them msd and jacobs also offers a similer box me i just run stock but then again im cheep :-) and i get about the same power and milage as they do
  6. 1bad82k5
    1bad82k5 1/2 ton status
    May 8, 2001
    185
    MT
    I think a stock hei runs pretty good, but if you want to go aftermarket I would go MSD. I have seen Accel HEI's and I don't think they are much better than stock, but MSD turns out a nice unit.
    eric
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I would have to say MSD. I have MSD products on my truck, and like them alot. I like there quality, and customer service. I don't have an MSD distributor yet, but every other part of my ignition system is MSD. Box, coil, wires.
    My buddies brother put an MSD billet distributor (non HEI) into his 63 Impala SS with HIPO SBC (400HP+/-), and he said it really helped out the motor alot. The distributor also looked to be very high quality, and by all his accounts worked great. So I'm sold on MSD and when I get a new distibutor it will be MSD.
  8. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    I've had good luck with both the MSD Pro-billet with their 8.5 wires and with Performance Distributors' D.U.I. (Davis Unified Igniton) HEI with their LiveWires. Both good products that give noticable improvements over stock. And I have to agree on the MSD boxes (6AL, 6AL Off Road, etc.). They are good stuff that (in my experience) give good results.
  9. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I agree, MSD makes good stuff. I have been running a Summit HEI and an MSD 6AL on my 388 stoker for about 3 years now without any problems. The MSD box makes a big difference, besides when you use one you can eliminate the failure prone module.
  10. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I run a Summit HEI and have been very pleased with it as well. I could recommend it.
  11. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Same here. My original HEI was starting to miss at high RPMs. I replaced the whole thing with a new Summit unit and no problems since.
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    no one has mentioned the Crane Fireball series of inginition stuff... any opinions?
    J
  13. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    DUI is unbelievable!!!!!!!
  14. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    Not impressed with the Crane, personally. However, I run screaming from everything with the Crane name...nothing but problems (for myself) from tech questions to warranty. Had a buddy that used the Fireball and it was a nightmare from installation to removal. Just my 2 pennies' worth.
  15. high&liftedup
    high&liftedup Registered Member
    Nov 14, 2001
    64
    CA
    I would NOT recommend the Accel 'blueprint" HEI. I had one for 6 months and the bearing went out which gave a lot of play in the shaft, which in-turn hit the rotor to the cap.. resulted in a huge BACKFIRE and bent a valve...! I bought a MSD HEI billet and No PROBS.... Quality stuff!..
  16. Redfrog
    May 4, 2001
    753
    IL
    sounds like it's going to be a Msd or DUI any more input?
  17. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    What's this I keep hearing about an offroad box? Are they an add-on or what?Thanks
  18. GrimWheeler
    GrimWheeler Registered Member
    Feb 22, 2002
    44
    Eugene OR, USA
    I'm running a Mallory Unilight, mainly because of "clearence" issues. It functions very very well, just make sure to put in the balost resistor.....or when/if your coil dumps on you, it will smoke the moduel in the distrubutor. I had that happen to me on Fairview peek, 3+ foot of snow, talk about a chilly night and a next day recovery, thank goodness a buddy of mine had the same distrubutor, It took a few days to get a new one from summit.
    Brian
    <a target="_blank" href=http://i.am/GrimWheeler>http://i.am/GrimWheeler</a>
  19. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    In my opinion DUI ( Davis Unified Ignition ) Is the best afterarket dist around for the money. Their basic street/strip unit is a lot cheaper than the MSD.
    <a target="_blank" href=http://www.performancedistributors.com>performancedistributors.com</a>
