best aldl software
Discussion in 'The Garage' started by gonger, Mar 22, 2006.
  1. gonger
    gonger Registered Member
    Nov 8, 2004
    42
    OK, I just got my aldl cable in from aldlcable.com today, good service, is winaldl the best software to use, it seems complicated at first look.
    curt
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    data master is nice if you are running the higher baud rate, other wise winaldl is a good program for data logging. If you are looking at making your own chips tunerpro has a version with a built in data stream to make it eaiser to burn chips
  3. gonger
    Nov 8, 2004
    42
    I'm just wanting to trouble shoot ecm codes and tune up, forgot to mention its in a 89 sub. thanks
  4. dyeager535
    26,979
    Gotta say tunerpro is my favorite. New, designer/developer is around to support it if the question/concern/issue is valid, it will do just about anything you want, and it's free. :)
    I'd suggest kicking him a few bucks if you like it, just to be nice. It is an improvement over winALDL, though winALDL will work.
