"Best" Body Lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 79Guy, Sep 2, 2000.
  1. 79Guy
    79Guy 1/2 ton status
    Jul 8, 2000
    178
    Southeastern VA
    \"Best\" Body Lift
    While I know that many don't like body lifts, I would really like to pick up just a little extra clearance.
    IF I were to use a body lift, any ideas as to the best quality brand / supplier?
    I've seen 2" and 3". Is there a "1" inch anywhere that would just add a little height.
    Thanks,
    '79 Guy
    1 Blazer - 7 Children
    http://79guy.coloradok5.com
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Re: \"Best\" Body Lift
    www.offroaddesign.com sells a real nice 1 inch body lift. That is the only body lift I would ever even consider using. The big ones just kind of suck.
    '73 K5
    Chevy good...Ford bad
  3. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Yes, bodylifts are the work of satan. But they add extra height without messing with the driveline, steering etc..
    Just remember they are not "bolt in" They take time because of the body-bolts that are rusted stuck. Some of the bolts have the "nut" hidden inside the crossmember. It will have rusted loose and it starts spinning and your only option is to start drilling or cutting. Then maybe welding to restore the bodysupports... I did a 3" on my 88. We have salt on the roads here in winther so maybe you'l get lucky and your will come loose easaly. But use rust-loosner and plenty of it..
    Good luck!
    http://www.espen88k5.coloradok5.com
  4. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Hey 79guy,
    Check out my site. I did a write up on installing a 1" body lift from ORD. I use to have a 3" body from performance accesorries, but I didn't like how the body lift affected my body on the trails. Seems like it was swinging my body around from the extra height. So I opted to lower it 2"s. It's also a good idea to change your body mounts while you're there. Might as well. Overall, it wasn't hard at all. Yes, rusted bolts are a PAIN in the A$$. But it wasn't too bad. I didn't have the problem Espen had on the bolts spinning. There are 10 bolts total. 4 of 10 bolts directly to the body. Good luck.
    Boss
    http://www.boss.coloradok5.com
