Best cam for torque in a 350?
Discussion in '1936-Present Suburban' started by orlandoc, Oct 11, 2002.
  1. orlandoc
    orlandoc Registered Member
    Sep 23, 2002
    26
    Puerto Rico
    I would like to do a cam change on my k30 suburban at the same time that I change the front oil seal. Does any one have a working combination without having to change my stock intake/carb setup? I'm running 4:56 and 35's. Your help will be greatly appreciated.
    Orlando
    "YB-LOW" /forums/images/graemlins/burb.gif
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    comp cams makes a cam called the "4x4 extreme" cam it's mostly for the low-mid range torque that us 4x4 guys need. /forums/images/graemlins/cool.gif
  3. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Stay with the low end torque makers like the performer or performer RPM intakes. Stay away from the high horspower stuff, it's all about torque!
  4. orlandoc
    Sep 23, 2002
    26
    Puerto Rico
    Thanks Guys,
    Greatly appreciated!!!
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Also, by sticking with the Comp 4x4 cams, your engine will still make good manifold vacuum. This is necessary to run your power brakes. If you want me to, give me some specs of your engine and the various cams you want to try...I'll run it through DeskTop Dyno 2000.
