Best Carb for Street/Strip 383?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Low76K5, Jul 17, 2006.
  1. Low76K5
    Low76K5 Registered Member
    Jun 28, 2005
    33
    Rapid City, SD
    Probably opening a can of worms here...
    I ran a 9.89 1/8th mile. Blazer came out of the hole great but would stumble or fall off between 5-6k RPMs. Even when it didn't stumble it just didn't pull hard at all above 4500 RPMs. I suspect my stock smogger '76 Q-Jet is the culprit. My builder suggested an Edelbrock Thunder Series 650. I go in for a my 1000 mile service soon and I will ask about adjusting the spark curve as well.
    383
    Edelbrock Perf Heads
    Perf RPM Intake 1500-6500 PRM Range
    Crane Z Cam 218/230 1500-5800 RPM Range
    New Stock Replacement HEI with hot coil
    Flowtech Headers
    2.5 Exhaust w/ Turbo Mufflers
    TCI 700R4, 2400 Stall Breakaway Converter
    Eaton Posi 4.11 Gears
    295/50/15 BFG Radials
    Thanks,
    Scott
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    750 Dominator :pimp:
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    A vacuum secondary holley 750.
