Best deals on Dana 60, 35 Spline Upgrade?
Discussion in 'The Garage' started by Sandman, Mar 9, 2004.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Looks like I am about ready to tackle this mod. Where is a good place to get a kit with everything for a good price? I have also heard that some shafts are like an 1/8" too long and ride into the locking hub causing problems over time. Anybody know about that? Thanks.
  2. bluejeep
    bluejeep 1/2 ton status
    Jan 9, 2004
    106
    Des Moines, IA
  3. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I also recommend Greg Youens at 4WDfactory at 512-759-6267. He has a night job as well so it's best to call around 11:00AM wen he wakes up.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, got mine from Greg too. Just talked to him a week or so back when I ordered yet another short side and CTM. Great guy with great service. Highly recommended.
    Seems like Stephen (ORD) also carries them. Another great guy with great service...
  5. mainiac
    mainiac Registered Member
    Oct 13, 2003
    19
    No problems with length?
    I think Stephen (ORD) was the one who mentioned to me that some stub shafts you find are too long and will rub on the locking hubs. Locking one side and unlocking the other.
    I assume this is a vendor spacific issue and just wanted to make sure. /forums/images/graemlins/dunno.gif
  6. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i just ordered that and new inner non neckdown axles....from alex at performance off road canter...he will beat any price....i got my SRW hubs from greg...im happy with him also /forums/images/graemlins/thumb.gif
    http://www.performanceoffroadcenter.com/
    1-866-540-7672
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I got mine from Performance offroad too. Cheapest prices too. Lower than 4wd factory and great customer service too /forums/images/graemlins/waytogo.gif
  8. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    If I'am correct I believe the issue with the longer 35 spline stub shafts has to do with the ones for Furd......................
  9. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Mine ride into the hubs..
    but they have been like that for 2 years..
    the hub hasn't failed..
    but..there is a chamfer on the stub now.. /forums/images/graemlins/doah.gif
    I'm getting slugs soon!! /forums/images/graemlins/peace.gif
  10. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    It has nothing to do with vendor. It's a Spicer stub either way. The problem is these are D70 stubs (rare application) and they are a little longer than the D60 stubs. Some people have more trouble than others, it's real close to being flat out too long, and tolerance stack along with locking hub selection seems to make the difference. Some people cut them off, some people space them out with special seals and bearings. I run slugs so it's not an issue for me at all. Bottom line is it does not matter who you get them from, just get them (if you need them) and find out if you have issues. If you do, address them as they arise.
    As for Fords, they don't fit at all in a Ford since the Ford stubs are shorter than GM anyway. The Ford guys cut them off and re-cut the lock ring groove or switch to GM hubs.
  11. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Thanks for the info /forums/images/graemlins/waytogo.gif
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    1-866-540-7672
    How much did he charge you?
  13. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I wonder whatever happened to the Yukon 4340 shafts... I've got a set of Ford 35sp. 4340s in mine, and they seem to do just fine. Only paid $169 for the set off ebay.
    -Dan
  14. mainiac
    Oct 13, 2003
    19
    Sorry I miss stated myself. What I was thinking was the supplier that you purchase them from may be selling you the D70 application stub shafts instead of the D60. This would of course be a wrong application, but possibly an explination for someone getting a shaft that is too long. Just an attempt at a possible explanation, I am not speaking from first hand knowledge. /forums/images/graemlins/dunno.gif
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    No problem. But there is no 35 spline D60 stub shaft. The 35 spline stubs are all D70 items... They just happen to fit the GM/Dodge D60s other than being just a bit long. Myself, I stack 5 nitrile o-rings under the snap ring to keep the back seal tightly seated. Works great with slugs.
  16. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Maybe I'll just cut off a hair before I install them just to be on the safe side then. I do plan on running hubs currently as it still sees the street. Or it will someday. /forums/images/graemlins/rolleyes.gif
  17. leadfoot067
    May 14, 2001
    1,563
    total was 525 shipped to my door......i got
    2 spicer 35 spline shafts
    2 spicer u-joints..5-33x or somethin....
    1 set of warn premiums 35 spline
    1 long side non neckdown spicer inner shaft
    1 short side nin neck down spicer inner shaft
