Best exhaust set-up?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by unsane, Jan 3, 2003.
  1. unsane
    unsane Guest
    What, if any are the best bolt-in exhaust systems for an 89? I was thinking on going with a good set of headers and total eliminaton of the Converter. I def want to use flowmasters for mufflers though. Any thoughts?
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've used the dynomax systems a few times and they have been OK. I used their headers also. the headers are not the greatest but they are not that bad either.
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I used Hooker Super Comp headers, Dynomax cat, and Flowmaster muffler and I love the combo; although, it was nothing even close to a bolt on setup ....
    Pics of my exhaust
    Thomas.
  4. unsane
    unsane Guest
    Well when I say bolt-on, I really mean no welding. I dont have a welder yet.
  5. dyeager535
    26,982
    191
    Newer converters don't hurt anything but your pocketbook when you replace them, if you don't have any emissions testing/visual inspection, won't get them locally soon, or won't be moving somewhere that has a emissions/visual inspection, it's up to you if you want to replace it or not.
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Doug Thorley Tri-Y headers, 2.25" dual exhaust (No cats if you can get away with it) with Flowmaster 40 series mufflers. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif (Borrow friends welder)
  7. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    On my 78 which came with factory dual exhaust and no cats, I used Hooker's headers and their "competition exhaust system". It was totally bolt on... fits very well, nice 2.25" mandrel bent tubing... add muffler of your choice. Not very expensive either... got it all from Summit. Probably not emmission legal on an '88 though.
  8. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Do you have part #s? I've been looking for a bolt-on exhaust setup for a K5. My '82 is still being strangled by the 305 manifolds. /forums/images/graemlins/eek.gif
  9. sandy78
    Nov 28, 2002
    84
    Utah
    Okay: These are Summit's P/N's and $. You can get more info. on the Holley/Hooker website if you want. I used HOK-2453 Hooker competition header: $157.00. Good design, nice thick flange, pass. side header "shorter" to clear front driveshaft, cleared mechanical clutch mech. w/spring relocation. Exhaust system: Hooker HOK-16528, dual 2.25" mandrel bent tube w/ hangers:$120.00. You may have to drill a couple of holes to mount hangers...fit and performance are excellent. Add muffler of your choice. I used Summit's SUM-630122 qty:2, $15.00 ea. Not too loud, but lots of flow. Sounds awesome when I dump the secondaries! Note: Summit charges $8 handling fee for all this stuff-- they pay the shipping. You may need to have someone weld in an O2 bung for your sensor. I did it just to use an air/fuel ratio gage to tune with. A local muffer shop did it for $25.00 including the bung. Anyway, let me know if you have any other questions.
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I might have to look at those headers. The dynomax ones barely clear everything on the passenger side and both seem to hang down low.
  11. cheyenne_77
    cheyenne_77 Registered Member
    Aug 5, 2002
    38
    Melbourne, Australia
    I'd definately go with tri-y's. These headers still maintain enough back pressure to increase bottom end power without sacrificing mid range to top end. (Truck is heavy and bottom end power is needed) Go for the 4 into 1 headers and you will lose bottom end power.
  12. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'm thinking about doing the same, let me know how if works out, or if you need a hand /forums/images/graemlins/thumb.gif
