best fitting headers, ceramic coating please!
Discussion in 'The Garage' started by Cornfield creations, Oct 9, 2006.
  1. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    anyone know the best fitting header brands out there? I don't want any issues with the fit as I have seen so many with fitting issues. Like oil filter clearance, frame clearance ext.
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    What year and model, and what engine? Will make a big difference in the info you get.
  3. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    my ceramic coated Dynomax's don't fit right and the coating didn't last. the flange is right where the lower shackle bolt is. They sure were cheap though. go figure.:doah:
  4. Cornfield creations
    Oct 19, 2005
    1,283
    Jasper, Indiana
  5. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    yeah i got a really cheap set of dynomax headers, they just barely clear the oil filter, rub my front shaft a little and the shackle bolt was a pain to get to when i did my lift... so don't get those... lol
  6. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Do a search on "headers" and you will get a ton of info. I went with ceramic Doug's Headers (Doug Thorley). You will find it is rare to get a set that doesn't touch anything unless your rig is bone stock. My headers hit the rear shackle because I had swapped in a set of thick ORD hangers. I had to bend them over away from the bolt and cut the bolt off at the nut. Here are a couple of threads for you:
    http://coloradok5.com/forums/showthread.php?t=155978
    http://coloradok5.com/forums/showthread.php?t=164736
    http://coloradok5.com/forums/showthread.php?t=186724
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    Maybe consider a set of 3/4 length Chevelle / Nova / F-body headers. They are much better for clearance than the long tubes are, but are still fairly long, not like the block hugging shorties.
    When I eventually run my duals, I'll be using a set of them for sure.
