Best Front Axle for Swap on 69' K20 ?
Discussion in 'The Garage' started by rencher2, Nov 23, 2006.
  1. rencher2
    rencher2 Registered Member
    Aug 31, 2005
    63
    Sitka,Alaska
    Im in the market for an axle to swap for a closed knuckle dana 8 lug, Its my understanding that the 78' is stronger than earlier years & has disk brakes , is this correct? A direct bolt on including a steering box would be Ideal . I found a good junk yard but need to make sure Im ordering the right setup. Any info would be greatly appreciated.:confused:
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    There were a few dana 44's. some had larger bearings and i forget what year that started. A 10 bolt is very comparable to a later model 44.
    Just go d 60 and live happily ever after:D
  3. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    Any ideas on a year for the D60
  4. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    one ton trucks up to 91..
  5. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    would all years up to 91' bolt right up with springs, driveline,& steering box swap?
  6. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    no,you would need conversion ujoints for the driveshaft, springs mount differently, a d60 uses bolts on the pass. side for half the spring plates..
  7. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    Will the D60 springs bolt up to the brackets
  8. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    Will the d60 springs bolt up to the chassis?
  9. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
  10. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    So as far as the swap I need Up to 91'D60 with springs and the conversion u-joint ? Will the 1ton steering box & linkage bolt right up also?
  11. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    i believe so.... but if you're gonna swap in a 60, might as well get some lift springs while yer at it...
  12. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    and iirc, it's 77 to 91
  13. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    d44s were external locking hub style until '78. then they switched to the stronger internal locking hub style. all open knuckle d44s up until '78 also had flat top knuckles, which is what you need for cross-over on d44/10b.
  14. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    A D44 from any chevy truck will be a direct swap, same for the 10 bolt, except for differences in brake fittings.
    D60 as mentioned above will work.
    D44's and D60's out of certain Dodges and Fords will work also, in case there is a chevy shortage.
    edit: case in point, I am swapping a Dodge D60 under my '69 GMC. There are a few little differences, but nothing major. It's also entertaining pissing off the diehard Chevy guys when I tell them this, they do not seem to understand the concept of Dana Spicer or parts outsourcing.
  15. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    no ford d60 will work with a chevy unless a ford transfer case is used, because ford is driver side and chevy and dodge are passenger side
  16. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    thats what i thought...
  17. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    since this is only brought up 20 or so times a day, I figured it did not need to be said. however, ford D60's of the 78-79 vintage bolt right up to chevy springs. and yes, you will need a driver drop t-case.
  18. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    but, this post is "best front axle" henceforth we only are mentioning running gear that will net the simplest swap
  19. rencher2
    Aug 31, 2005
    63
    Sitka,Alaska
    So nobody has an answer for the steering box ?
  20. 79k20350
    Nov 22, 2004
    7,757
    Ct
    umm im 90% sure that a d 60 uses the same 1310 joint...
