Best Header for SB...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sturzinator, Sep 17, 2001.
  1. sturzinator
    sturzinator Newbie
    Jun 12, 2001
    4
    Bum-Frick Montana
    Looking for the best header that you guys have used that will 1) clear the A/C bracket, and 2) WON'T LEAK!! Price not an issue here.
    OR, what is involved in modifying the A/C bracket to accept most headers?
    Vehicle is an '85 K5 Jimmy w/TPI 350, and A/C.
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I have Edelbrock TES headers and like them a lot... check them out on their site www.chevycagal.homestead.com/steph.html
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The Edelbrock TES is an easy bolt on with no modifications to any brackets. I'v had mine on for 2 years with no leaks at all. I just retorque the bolts once a year.They are very well made and build good torque. However they may have front driveline clearence problems if you have over a 4" lift.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze>http://coloradok5.com/gallery/Thunders-Blaze</a>
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue>
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Doug Thorley's are my fav..... their legal in all 50 states......
    C'moe
    <font color=black>the blazer is "Back in Black"
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My El Cheapo Hedmans don't leak, and clear the A/C, as well as all the other questionable clearance areas by a long shot. Mine's also an 85 - I'll get pics if you'd like.
    Special thanks to those lost from IAFF Locals 94 and 854 - You shall never be forgotten
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  6. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    THORLEY
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I personally like the heddmans. They are cheap and dont leak. Get the high temp coating and they will last forever. I run the heddmans on my firbird and love them. When I get around to it I will put them on the Jimmy.
    86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  8. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I've heard many good things about thorleys... otherwise I will always go Hookers. Never had a problem with them, for cheapies I'd had decent luck w/ Dynomax and a go quality gasket, but they take a bit more work to fit then the Hookers.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  9. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    If price is not an option than you need the THorley's, HANDS DOWN!
    But is you wanna save the money for other things then go with any of the others they have mentioned. But the
    Thorley's have a damn thick flange on them to do nothing more than to help prevent the preverbial header leak problem.
    "you know... the guy with the BAD A$$ spring perches!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  10. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    ahhh, I have Hedmens and they LEAK. I've had them on my rig for about 6yrs now and the pass side flange is warped and leaks. I've tried all the difeernt styles of gaskets and the only way I'm gonna stop the leak is to double up the gasket on that side.
    For low end torque the Tri-Y design is the best!! Thorley has a great Tri-Y design and the flange is HELLA thick so they should not warp. I will go with Thorleys when I redo my exahast system.......soon, hmmm I think I just figured out what to get for Xmas[​IMG].........
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  11. sturzinator
    sturzinator Newbie
    Jun 12, 2001
    4
    Bum-Frick Montana
    Thanks for all the suggestions!! Sounds like the Thorley's have it... and the price to match it WOW!! Now if I can just find an "under the table" shop to mount a true dual exhaust I'm in there!
  12. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Well you said price was not an issue!
  13. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    will thorleys clear the ORD's extended shackle mount i read somewhere that someone had trouble with them rubbing on the front shackle.
  14. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    While we're on the subject, what about spark plug clearance. The Thorley Dual Y design looks like it gets real close to the spark plug in a few places. Anyone running these? I had the Flowtech Tri Y which were close but manageable as well as the Hookers which needed insulation boots to prevent ambient heat from hardening a few of the plug caps. Anyone?
    What, Me Worry?
    <a target="_blank" href=http://www.echobit.com:81/k5/> The 'BEFORE' pictures</a>
  15. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I got some hooker super comps, and a pair of flowtech afterburners... I like both headers, but the flowtechs don't clear the factory oil filter with the stem for the oil coolers lines [​IMG]...
    for the price ($185 for ceramic coated), and the fact that the way I use this k5 an oil cooler isn't a bid deal, I love the headers...
    my supercomp hookers only have 2 plugs that you cannot get to with a rachet (rear 2 on the left above the starter), and they clear the filter real good. however, there is also a price tag of a little over 300 so I'm about 140 cheaper on the flowtechs.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  16. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You can also get NKG spark plus which are shorter and will help some. There is a heat wrap for headers too. Just make sure if you wrap them it won't void the warrenty on them....
    GOD BLESS AMERICA!!!
    &lt;&gt;&lt; MARK 1:17 &gt;&lt;&gt;
  17. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    napa (among other places) sell a real nice spark plug wire boot insulator, its that asbestos like material (maybe it is asbestos, dunno) with a metal ring on one end.. they're real thick and work excellent.. I think they look good too but they're fairly pricey.. I needed em though.. with my stock exhaust manifolds, a new set of plug wires wouldnt last a week.. probably because I didnt have the stock tin heat shields on though.. and I wasnt about to try and put em on.. those things are bogus.. go with the heat shields and you'll never look back
    mike
  18. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    I have DynoMax hedders that hit ORD's extended shackle! Next time I'll go with some shorties.
    Bo
    If it breaks, it wasn't good enough!
  19. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    I have the Thorleys on my truck and have had zero problems of any kind. Easy to put on. They clear everything. They clear the plugs, the boots, the ORD shackles on my truck and everything else. They are very close to the passenger side shackle and it looks like that shackle seeps more grease out of it than the others (greasable) but that is easy to fix, just put more grease in it. The headers don't leak either.
  20. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Case closed!!!!
