Best headers for a 350 K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zcarczar, Mar 1, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Im in the market for some new headers for my k5, its got a TBI 350, and it has headers on it, but they are warped at the flange, i was looking at the doug thorley's, has any one tried these, i was also looking to go dual exhaust and lose the cat and go dual exhaust, is this a good idea? or should i leave it with a single cat and go dual after the cat?
    by the way i know the smog tech guy at my shop so smogging is not a worry
    My Website<a target="_blank" href=http://www.zcarczar.com>www.zcarczar.com</a>
    89 K5 350 TBI 35x12.5.15 BFG's 4" lift
  2. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    I have a friend who is running a set of Tri-Ys. But they were custom made at a shop in Seattle Washington. I think it is called Stans Headers. THey might have a home page. THey are $pendy. In my opinion I would leave it single. Dual will get louder. Depends on mufflers, size pipe, etc.
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    If you don't have the $$$ for the Thorleys, I'd recommend Flowtech Afterburners. I used them in my Blazer and still would be using them if I weren't swapping a 454 with a set of Thorleys.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  4. zcarczar
    Feb 10, 2002
    2,495
    I could really careless about noise since im 16, i do like the thorleys, and i was also wondering is there away that i can make it so the exhaust crossover tube doesnt run under the front driveshaft?
  5. 85Jimmy
    85Jimmy Registered Member
    Oct 30, 2001
    97
    Great Falls, Montana
    I say you can dual it!!! I got a set of Hooker Comp headers Part#2827 and the dual exhaust kit that they make Part#16528,then i just put on some cheapo thrush turbos and it works awesome.
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Thorley's all the way baby!!!! And never look back!!!
    Its the popping, rumbling, roaring, twisting, flexing, grinding, so you can wheel anywhere medicine[​IMG]
  7. zcarczar
    Feb 10, 2002
    2,495
    Ive decided to go with the thorleys, but i have one question they have 2 differents sets of headers on their site for k5's, one for a stock hieght truck and the other with a 4"-6" lift, i was thinkin i should go with the ones with for the lift since my truck is lifted
  8. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    I used dynomax headers. they come jethot coated-lifetime warrenty against rust. $210.00. Dynomax dual pipes kit. it goes over the crossmember. $100.00 . added two flowmaster 40 series $60.00? each
  9. 87GMC
    Nov 5, 2001
    653
    Olathe, KS 66061
    I used dynomax headers. they come jethot coated-lifetime warrenty against rust. $210.00. Dynomax dual pipes kit. it goes over the crossmember. $100.00 . added two flowmaster 40 series $60.00? each aslo had to weld an O2 bung to the pipes
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Bingo except I had 12" glasspacks. Worth every penny, that kit is.
    I have straight pipes now. If it's still not loud enough, I'll get a bigger motor.
    Tim
  11. sinchphoto
    sinchphoto 1/2 ton status
    Mar 7, 2000
    366
    Southern California
    I've heard that thorleys are the way to go. I have a set of hooker comps, just took em off got em sandblasted and painted. they work great. nothing bent no leaks.
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think the stock ones have one side turn inward to go to the cross over and the ones for lifted trucks are straight. You should call them to find out.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  13. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    Just put a set of ceramic coated JBA's on mine and they are unbelievable! Just a little pricey.
  14. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    i have a set of the thorly try y's and they are great huge power gain and no yeaks yet 6 monts 10k miles. they quote the power gains at 25 for single exhaust and 15 for dual it has to do with the y pipe actually acting like another collector. the only drawback is that they do not keep these instock andhave to be made it took me 3 months before i got mine. i paid $415 for mine with the y pipe which isnt bad when you figure that they are ceramic coated which will cost you at least $250 alone for any header and a y pipe goes for $100 bucks, and the thorlyes are mde extremely well and bolt up to the factory exhaust
  15. zcarczar
    Feb 10, 2002
    2,495
    Thanks for all the responses, I'm gonna go with the Throley's, Im going to call them tommorrow and find out the difference between the ones for lifted and non-lifted blazer,
