Best Headers???
Discussion in 'The Garage' started by skink4president, Oct 6, 2005.
  1. skink4president
    skink4president Registered Member
    Mar 5, 2005
    79
    orlando
    I've searched the forums and can't find a thread specifically dealing with this issue. I'm planning on putting a new exhaust system (headers to tailpipe) on my '73 K5 and was wondering what everyone thought were the best headers out there. Hooker? Thorley? Hedman? Others???
  2. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    You can never go wrong with Hooker.
  3. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    www.stansheaders.com expensive but will worth it, they have thick 3/8ths flanges ball and socket collecters that don't use a gasket so they don't leak. They're very similar to thorley's as far as tri-y design. HIGHLY Recommended
  4. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    Really depends on your price range. I've heard that Sanderson and Thorley headers are pretty top notch. But they cost more than the Hedman or Hookers. Unless you want the top of the line Hedmans or Hookers. I personally think that you cant go wrong with a set of ceramic coated (inside and out) Hookers or Hedmans. You might try and find one with a thicker flange, as the thin ones tend to warp easier. But you can always cut the flange to remedy that. As far as my personal experience, I had a set of Hookers that the flange warped on my 350. The Hedmans I ran never warped. Didnt notice any performance difference between the two.
    There are quite a few header manufacturers you can check out...Edelbrock, Sanderson, Hooker, Hedman, Flowtech, Gibson, JBA, Dynomax...
  5. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    I've never had a problem with my hookers. never leaked.
    My Hooker headers aren't bad either
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Ive had Hooker headers (81 Blazer), the super comps cost more than others but never had probs. My hot rods (69 Malibu, 72 Nova) have had ceramicoated Dynomax headers, worked fine. Right now I'm running cheap $90. Summit headers in my K20 and seam to be working ok. A buddy of mine ran some flowtechs on his Blazer and they would hit. Another buddy got some Headman's for his Ford and they would not fit at all, turned out Headman made a batch of headers that were formed/shaped wrong. But I believe most decent name brands should be fine. Dont bother with the paper gaskets that come with 'em, go down n buy some decent gaskets. And dont forget to check the header bolts. I once had an exhaust leak that kept getting worse, when I finally decided to tighten the bolts the back one by cyl #7 had loosened up and fallen out!!
  7. dyeager535
    26,982
    191
    Hedman Elites fit my truck very well, and were pretty cheap. Use the much better ball/socket setup than the flat flange most other headers have, come with thick flanges, thicker walled pipe, and ceramic coated outside.
    Only about $200 from Summit IIRC.
  8. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    :waytogo:
    I didn't know those had the ball/socket setup. Good to know :waytogo:
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    who doesnt like hookers? :haha: :haha:
