Best heads for my TBI motor
Discussion in 'The Garage' started by COCHEV, Nov 26, 2004.
  1. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Thinking of sprucing up my 95 silverado a bit and i want to do heads and a cam on it. been kicking around these three options:
    vortec heads
    s/r torkers
    BMPP cast iron tbi heads
    aluminum is not in the budget. i have a crane truck power cam to go along with it that is in the 214-218 range (can't remember off the top of my head)
    the BMPP heads sure seem like a good deal to me. anyone have any experience with these?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    S/R torquers
  3. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    what do yall recomend for aluminum heads? i would like to rebuild my tbi sometime, but dont have the funds to do so anytime soon. /forums/images/graemlins/doah.gif
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] DART !!!!
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Why would you put aluminum heads on a TBI engine??
    An 8.5:1 engine hardly needs aluminum heads to begin with.
    S/R tourquers are a much better investment.
    Start pushing 10.0:1 and aluminum heads would start lookin better.
    If the plant starts lookin like that then TBI isn't even in the picture anyway.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Aluminum? No brainer. AFR.
  7. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    /forums/images/graemlins/smile.gifVortec heads
  8. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Get the S/r torquers. Bit better flow than a vortec and a way heavier duty casting.
  9. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I'll vote for the S/R Torquers as well. I've had a pair of the 67cc 2.02/1.60's on my 388 for some time now and would recommend them. If I were to upgrade, the only heads I would get would be a set of AFR 195's. /forums/images/graemlins/waytogo.gif
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I also vote for the S/R torquers. If I ever put a set of real heads on my 406 they will be AFR 195cc alums for sure.
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Add one more vote for the S/R's /forums/images/graemlins/thumb.gif There are better ( higher flowing ) heads out there but if you want to make good use of the T.B.I. set up the S/R's are a fine choice and , as stated above , are a MUCH better casting .
    Tom
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Iron heads. centerbolt World S/R Torquers are the best for TBI IMHO.
    If you want to save a few bucks get theseSDPC L 98 Heads They work great on TBI trucks and flow plenty for TBI. They orginally came on the TBI Birds and Camaros.
    Aluminum heads are not really worth putting on a TBI truck.
    Their only real advantage on a low compression engine is weight savings. On a 5000 pound truck 45 pounds wont make any difference.Except to lighten up your wallet /forums/images/graemlins/wink.gif
    On a low compression engine Iron heads of similar flow rates and compression ratio will make more power than Aluimnium heads of similar flow ect.
    BTW Those numbers you gave for the cam may require a custom chip.
  13. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    thats the 3rd option i had listed in my post. i'm leaning towards them cause they are so damn affordable. this is not going to be a race engine. just want to spruise up the ol' work truck. anyone with a 350 tbi in front of a 480LE knows they are pretty doggy.
  14. sublmnl1990
    sublmnl1990 1/2 ton status
    Nov 8, 2004
    419
    Virginia Beach Va.
    If you add these new heads to your motor what other mods would the motor benifit from aswell? That would work with these heads? What type of cam would you suggest? Should you leave the tbi alone or do you need to adjust it also? Mine is a 1990 suburban w/ the 5.7l. Thanks /forums/images/graemlins/burb.gif
  15. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    You can get a set of the s/r torquer heads complete for $799 from summit. Here is a link to them on summit
    These are also the heads I am going to run on my 355 TBI also.
  16. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i'll give you that they seem to be a heavier casting, but as far as flow, the Vortecs win. maybe not by published magazine numbers, or advertising numbers, but i have worked with a flow bench and a number of iron heads, and Vortecs were up there.
  17. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    CHP did a bench test on a bunch of heads and the Vortecs did outflow the S/R's by a lil bit.
    But with a chamber size of only 64cc's...
    If all you are doing for an upgrade is heads then stick with the same chamber size which for a stock TBI plant I believe it is 8.5 with 76 cc heads.
    64cc's will send the ratio trough the roof and the quench will be horrible. (as in none)
    The Vortecs flowed 239 the SR's 221 at .500" lift
    Bang fer the buck without swapping pistons the S/R's are the best buy.
    And for the cost of pistons to accomodate the heads....
    The Vortecs are great heads from what I have seen they just are not as versital as a set of heads that are offered in 76cc chambers.
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    funny, every TBI head i've ever seen was 64cc. /forums/images/graemlins/dunno.gif
    another funny thing, you say quench will be horrible. if you're swapping heads, that's the perfect time to fix that problem! /forums/images/graemlins/screwy.gif
  19. COCHEV
    Jul 9, 2002
    4,055
    Washougal WA
    yeah, these are for tbi and they are 64 cc too /forums/images/graemlins/dunno.gif
  20. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Hmm maybe my info is wrong, I was led to believe that the 285 + HP plants got the 64cc heads.
    And truck heads got 76cc's
    I just tore down an 88TBI plant and other than the piston and ring material pounded into the head they looked to be the same as my 993's with 75cc chambers.
    The pistons were the same size (stock dish = 0 quench)
    There is no quench with those pistons.
    That lil bit of piston head is not gonna do anything for that effect.
    There is nothing to squish against, the mixture just gets squirted out a big azz hole.
    Unless I was looking at some hybrid truck engine that magicly applied material to do this.
    I'll swing by and grab that head and measure it to put the matter to rest.
    I seem to remember the 64cc castings I was looking at having alot smaller chambers than the ones from the 88 TBI truck plant.
    GM Performance Parts Small Block Chevy TBI Cast Iron Cylinder Head. This is a good flowing head for use on fuel injected engines used from 1987-95. Originally this cast iron head was used on the 285hp 350 crate engine which is no longer available. This is an excellent head for increased performance on all TBI cars and trucks. Price is per head.
    If that was stock in an 88 4x4 3/4 ton basic am radio glad ya got heat burb I got a hell of a deal.
