best HEI dist. for the money
Discussion in 'The Garage' started by surpip, Nov 15, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    my budddy has a 87 k5, he wants to upgrade to HEI
    so i want to know which is the best for the money?
    also to install it it is just 3 wires right, 12v+ gnd. and tach if you got it?
    i cant rember what i hooked up on mine.
    thanks
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    the 87 should already have a version of the H.E.I now. A small cap style with a seperate coil. It's computer controlled timing though. A regular H.E.I will not work.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    should still be able to swap a HEI in right?
  4. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    no. A regular HEI is NOT set up for the stock computer. The distributer in there now IS an HEI, just the later model with a seperate coil. It will drop in, but it won't run!! The EFI needs the signal from the stock distributer. The wiring is different. Rewiring would be a waste as the Seperate coil design IS better as the coil doesn't get as hot as with the "older" desighn HEI.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    hummm ok, the reason he wants to change is that the hole in the dist. for the cap is stripped out, so i guess he just needs to go get one from a junk yard if he can find it.
  6. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    You can buy a new one for about 150 bucks for stock,I think msd makes a drop in replacement too.
