best HEI timing setting for smog check?
Discussion in 'The Garage' started by monster man, Oct 31, 2005.
  1. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    what is the best setting in degrees for an HEI 350 4 barrel for a smog check?
    last year, the tech says I barely passed, I told him that the only thing I had changed was to an HEI ignition from a points setup, he told me my ignition was probably too far advanced, that HEI's don't like barely any advance. Before, my points were set at 8 degrees advanced, so this year I have it down to 6.5 degrees, and pretty lean, and she's running like crap. Well, not stumbling or anything but a pretty rough idle, and she dies when cold. Definitely smells very very lean, so it may pass, it may not.
    But, is it true that HEI's are generally set closer to TDC than with points?
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I think the timing is for the spark is in relation to the rotating assembly. It should not be matter if you have HEI or points. I'd make sure you have the same curve for the advance systems.
  3. monster man
    Oct 20, 2003
    282
    Reno, NV
    thanks- I'm not sure what the old curve was or the new, but they're both vacuum advance and I almost failed on the idle test, 2500 RPM was fine. So, I'm assuming he meant the initial advance was too far, so I retarded it a couple degrees, we'll see if that works
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    don't run it to lean if you run to lean you will fail as bad if you ran rich
