best hubs for the least amount of money
Discussion in 'The Garage' started by tmaxxer9, Feb 20, 2003.
  1. tmaxxer9
    tmaxxer9 1/2 ton status
    Feb 12, 2003
    195
    Minnesota
    I was wondering what the cheapest brand of hub lockers are and yet hold up really well.
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    hmm, just spend the money oh warn premiums, then buy the fuseable links, and if you do ever break them itll only cost like 20 bucks to fix em, Atleast i think.... Its hard to find Cheap stuff thatll last, youll find that out real quick, but some people get lucky, or they dont use it as hard as others, and cheap parts will last longer, What are you plans as far as wheeling?> you gonna be hardcore? or just messin around occasionally?
  3. tmaxxer9
    Feb 12, 2003
    195
    Minnesota
    I plan to do a little bit of hardcore off-roading once I get into it a little more. I heared that there were such hubs called m&m hubs. Is that corect? I also heared that they were $400 a pair and unbreakable. /forums/images/graemlins/confused.gif Not that I am going to buy them.
  4. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    nothing is unbreakable... ive never heard of m&m maybe somone will chime in and know about em
    my piece of advice, is dont skimp, itll only bite you in the ass someday...
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    cheepest and still real strong:
    Stock Spicers from the junk yard.
    M&M I would have to guess is mile marker
    All the after market hubs are of the exact same design! Warn has the patent and when anyone else makes them they have to pay Warn to do so.
  6. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    i have a set of mm hubs for a 19 spline gm 10 bolt, if they woould fit u id sell them, ii aslo will be selling warn premiums with the fuse + spares for the same axle. the warns are new, never wheeled on. but on vehicle for about 1 month.
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    haha i cant belive i didnt catch that MM mile marker
    i guess Flanges would be unbreakable, but they dont unlock....
  8. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Junkyard-stock Spicer. Only ones that are not alum.
  9. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,603
    554
    Wasilla AK,
    Any hub except SUPERWINCH they S$%# A$$ How far are you from duluth /forums/images/graemlins/truck.gif
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Just buy some Warn Premiums and be done with it. If you don't have a front locker or it is an ARB then put the hub fuse in it for some extra pertection. Do it right the first time and don't worry about it. You will be pissed if you buy a cheap hub, and it breaks when you really need it.
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Spicers fron the yard are stronger than Warns from a box. They are just a PITA to put together. The best feature of the Warns is they are 3/4 turn, the Spicers are 1/4 turn, this makes the Warns easier to disengage.
  12. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, I have heard that Spicers are stronger, but I haven't been able to find a pair in a yard yet. I personally like my Warn Premiums. I have had them for over 2 years, with no problems. Actually I just bought another set for spares. I really like the 3/4 turn too.
  13. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Are there spicers for the 60?
    you got any pics of the spicer hubs?
  14. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I heard they were good. But I guess not
  15. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    get some warn premiums and go go go. /forums/images/graemlins/grin.gif
    j
  16. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I always use Warn Premiums. The price is inline with everyone else and they hold up.
    You might be able to find a similar hub for less, but it's probably not worth the bother. They should cost about $100 for a D44, IIRC. How much cheaper are you really going to find something?
    -- Mike
  17. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    There are Spicer D60 hubs, but they are not common, at least around here. I don't have any close up picks of my hubs but any pics on my site of my red & white GMC have the Spicers. Or did you want an exploded view from a manual? I can scan that if you need it. As was said above the Warns disengage easier and I will add they are much simpler to install. I've run the regular and premium Warns, Spicers, and Wolverenes. On different trucks over the years, all have been on 10B or D44. The stock hubs on my D60 LOOK like standard Warns, but I don't know what they are.
  18. yellowK20
    Dec 26, 2002
    7,603
    554
    Wasilla AK,
    I have had no luck with them The allen bolts strip out and then you can't get them out Click on my user name and look under "user's post" And look for the post "grease is good " It tell's a pretty good story about my experiance with them . I like Warn premiums or stock spicer hubs I also Use drive flanges From Full-time trucks I know those don't break /forums/images/graemlins/truck.gif
  19. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    When I bought my D60 (truck still attached), There was one F*rd hub and one Superwinch hub. The Superwinch was flimsy, had let water in (rusty) and fit poorly. It made no positive impressions.
    I choked down the price for a set of Warn premium D60 hubs and kept the F*rd one for a spare.
