Best Jethro way to cc your heads?
Discussion in 'The Garage' started by 73k5blazer, Aug 5, 2005.
  1. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Ok, who's got the best tried and true method of getting a somewhat close measurment of your head chamber volume?
    A friend of mine suggested I goto Tractor Supply Co, and get an animal vaccination syringe?
    Anyone got some cheap methods?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Well, I bought the largest animal vaccination syringe at Tractor Supply co, $1.89 (60cc), plust another $1.10 for the needle tip. (Veterinary use only!)
    I had a piece of plexi-glas, cut it to size and drilled a fill hole in it, slight gease around the edge of the chamber, placed the plexi-glas over it, and filled her up. I did it on the head I knew the size of first, and it came out almost exactly right at 65cc (the head is 64cc).
    So it works, the only trouble I had, espcially on my old heads, because the volume is greater than 60cc, I oculdn't refill the thing fast enough because some fluid was slowing leaking out through the valves while I was trying to refill the syringe, but a little grease on those valves took care of that.
    If they had an 80 or 70cc syringe, that would be better, but 60cc was the largest they had. (that's alot of dope!)
  3. i8yrsuv
    i8yrsuv 1/2 ton status
    Aug 31, 2003
    327
    Santa Rosa,NOR KAL-IFORNIIA
    Whoo !! That way ROCKS !! :bow:
  4. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Summit sells Comp Cams cheapo kit for $25 that supplies everything you need includind burette and plate :bow:
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I did mine the exact same way!! :D :D
