Best lube for mechanical advance
Discussion in 'The Garage' started by Blue85, Jun 26, 2005.
  1. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    I searched a lot on this and didn't come up with anything conclusive.
    What is the best lubricant to use on on the mechanical advance section of the distributor? I tried white lithium, but it gummed up. I tried WD-40, but it dried up and left some gum. I heard a suggestion of graphite, but I'm not going to put something conductive in there. Currently, I am trying ATF.
    What has someone used successfully? I am tired of cleaning this out every 4 months. Is it lubed from the factory or is it left dry?
    I know it's stuck again when my idle roughens from too much advance.
    Thanks.
  2. dyeager535
    26,982
    191
    I believe they are installed dry.
    The black plastic(?) should allow the weights to slide across them. That is if I remember my non-EFI distributors right.
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I use either engine assembly lube or CV joint grease. Both stick well and aren't real thick. Only takes a little bit of either.
  4. Blue85
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    There is no black plastic. I was actually looking for some bushings for the weights to pivot on and didn't find any in curve kits or rebuild kits. Where the bottom of the weight slides, that is metal to metal. Also, the two pieces at the top of the distributor shaft slide metal to metal. Dry is definately better than gummed up, but the key is keeping it clean.
  5. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    bushings..
    I have used the plastic bushings that come in a MR.Gasket advance "curve kit" that has new weights and springs with the bushings in it--they fit stock weights too(you might need to drill out the holes if they are "egged" out!)...
    As for lubricant,I usually dont use any,I just wire wheel any rust off the weights and pins and re-assemble everything--I suppose you could use that silicone High Temp "Tune up grease" like they use under an HEI module and plug wire boots if you wanted--that wont conduct electricity like some other greases or vaseline might and cause a misfire... :crazy:
  6. dyeager535
    26,982
    191
    OK, that's an Olds/Chev difference then, I knew I had seen black plastic "bushings" in that location.
    I've seen/used the weight pivot post bushings in the Mr. Gasket kits too.
  7. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    hey blue could u post some pics? of ur k5
