Best oil for high mileage engine?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigk, Oct 6, 2001.
  1. bigk
    bigk 1/2 ton status
    Jun 13, 2001
    358
    Mendon Illinois
    I just got a Suburban with 160K on it. What's the best oil to use in a motor like this? I haven't had a chance to see if it burns any yet. If it does, any suggestions on oil additives? It does do the typical blue puff when you first fire it up, valve guides, I know. Thanks.
    Karl
    Temporarily Unemployed Underwear Model
    87 3/4 ton
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Valvoline makes a special oil for higher mileage engines like yours. Its come in a red bottle. I suppose I'll give it a whirl next change because I'm about to hit 100,000.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I ran the "extended life" oil in my Dads F*rd. The only thing it did was burn more oil than before. I think this was due to the fact that it is a partial synthetic, and it slips past the rings easier then normal oil.
  4. Tatman
    Tatman Registered Member
    Oct 2, 2001
    80
    Indiana
    I've heard of the nightmares of rebuilding an engine after using Marvel Mystery Oil, though I have never rebuilt one after it's use.
    My K5 currently has a 307 which has BLOWN smoke since the day I got it. Have tried Smoke-B-Gone among many other additives to stop smoke, with no real results.
    Soon to replace the 307 with a 350 I'm rebuilding, I decided to give the Marvel a try. Walla!... the K5 is no longer a mosquito fogger.
    I don't know whether I'd use it in a motor you'd want to rebuild, but I'd heard the praise of the life giving qualities of Marvel since I was a kid just starting to drive. Though I had never used it before, knowing the condition of this 307, I am impressed. Even added a bit of power, I'm sure due to the sealing of rings, seals, etc.
    Don't know what your plans are for your motor, but this 307 is heading for the boneyard as soon as the 350 is finished, and I see the results the Marvel did for it. Just my .02 worth.
    www.saddletramps.com/BlazerK5.htm
  5. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    Mobil one syntec!!!!
    as far as the valve seals.....sea-foam, if you can find it!
    Most overheard question in the Carolinas...................."Randy who"????
  6. CAROLINAK5
    Aug 2, 2001
    242
    also use WIX filter or the NAPA gold, supposedly the smae thing.
  7. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    Sea-Foam is great stuff. Totally cleaned out my old Oldsmobile, and lots of guys in my old car club used it with good results.
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    what is sea-foam?? BTW with my 226k mile 400 i was told 20w50 oil to help the old tired rings seal better...have not tried it yet....
    -zakk
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
  9. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I run 20w-50 in all of my trucks...only one of which has over 100,000 miles....just does the trick for me and i have had many of mechanics tell me they have had 350's specifically run 250,000+ using 20w-50 now i can get away with this down here in south louisiana because of the heat it still makes the 20w-50 flow smoother because of all the heat but I also find it doesnt break down as quickly. The winter is a different story...kinda like cold sludge, until it heats up its pretty thick, does the trick for me though i think up north you'd have more problems with this oil in the winter...
    I also add marvel mystery fluid to my engine at every oil change with no harmful effects, actually last time i pulled the valve covers on my 350 with just under 10,000 miles everything still looked good as new also with my 350 with 35,000+ So i can't really see any nightmares about it....i think the things people find are other additives....
    What? You think the hole is too deep? Lemme see...
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  10. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I run 20w50 in my jimmy and burb. The jimmy motor has 30,000 miles and the burb has 58,000 miles. In my firebird I run straight 50 weight and the motor only has 3,800 miles on it. Always run a thicker oil when a car gets alot of miles on it, or you put it through hell. I break down the straight 50 weight in my firebird every other week in race season.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  11. Tatman
    Oct 2, 2001
    80
    Indiana
    The Marvel Mystery Oil nightmares I was told about was something about a glaze on the cylinder walls and such. Supposedly it is hell to bore or hone. Like I said, this is my first time using it and it worked wonders for the smoke problem, but have never seen for myself what these guys were moaning about.
  12. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    If It only pisses off the guy at the machine shop but helps high mileage cars &amp; trucks I going to start using it on all my vehicles
  13. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    So how much of this Marvel Mystery Oil are you supposed to add to the crankcase. My wife's old Safari has 117K on it and smokes on startup only, and only when cold.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Valve guide seals are easily replaced. I'd bet a novice could do it in 2 hours or less.
    Synthetic anything is going to both burn and leak more. The molecules are smaller and will find any leak.
    As far as oil for a well worn engine, just find something thick, but not too thick for the weather. 20W-50 summer, 10W-40 winter.
    Tim
  15. Speed-demon
    Speed-demon Registered Member
    Sep 12, 2001
    38
    Alberta
    MOLYSLIP!!! www.
    90 percent of the additives out there have teflon in them which gums up your motor. I do torque tensioning with hydrolic whrenches at work. on my enginering table of torque with different lubricant's, Molybdenum Disulfide takes first place.[ MOLYSLIP] It goes from moly to chain oil and it takes a third of the ft-lbs to get the bolt tension with moly.
    If you get a cracked head and you had molyslip in it, you would have a chance in catching it because moly gets in the surface of the metal and won't break down from the antifreeze&amp;water. I have sold many of lemon's with this [censored] in them and have never had them come back on me. I would never buy a car with this [censored] in it because it masks so many problems because of the loss of friction it creates. They would have to change the oil without it and let me see the car running up to temp. You can't put it in a new or rebuilt engine until it has been broken in because your rings won't seet and it will [censored] up. So anyways remember that most of the other additives are pritty much just normal heavy oil with teflon in them and if you ask teflon if they really endorse this you maybe in for a shock! lol
  16. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    20w-50!!!! 10W-30 was cooked, 10W-40 had to be topped off, and 20W-50 loves the heat!
  17. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    This may be contrary to what most people think, but I have run Pennzoil 10W-30 in all my vehicles for as long as I can remember. I live in VA and it get's pretty hot. As a testament I have an 89 S-10 blazer with the 4.3 and we have 287,500+ miles on it using nothing but 10W-30. I know this is the orig motor b/c I have owned it since new. I towed a 3500lbs boat in the summer heat 95+ for 2 years. No problems.
    I can see if you live in AZ or lower TX going to a higher weight oil, i.e. 20W-50 but if you live where it gets cold at all you could be doing more damage in the winter than in the summer.
    Just my thoughts,
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  18. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    My old tired 400 has about 190k miles on it. I recently started running Valvoline Durablend in it. It definately helped the motor. I swear by synthetics now. My motor used to smoke and ran crappy, but just a change in oil types helped me. Get a semi-synthetic or fully synthetic if it doesnt use much oil. Oil pressure was improved, no more light haze of smoke from the rings.
    Mudzer 1978/91 K5
    <font color=blue><a target="_blank" href=http://www.mudzer.rockcrawler.com>www.mudzer.rockcrawler.com</a></font color=blue>
  19. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Stay away from the Valvoline "MAX LIFE"!!!
    Put it in my Jimmy 215k and it smoked so bad the guy behind me couldn't see!!!!!
    wen't back to 20w50 and it still smokes but not nearly as bad.
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
