Best Option?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Sep 24, 2000.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I was crawling around under the truck checking for loose parts cos I've been hearing an annoying popping sound whenever I hit a bump,or rut, etc.....Anyway, on the left side, the bracket for the leafspring, where the bracket is connected to the frame, it has a busted rivet, I think this is where the pop is coming from, there is a small gap and shiny metal. My question is, is it acceptable to put a grade 8 bolt and nut in there? Or is there a stronger option? Take it easy, have a good night.
    creepin' and crawlin'
    Jim
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I would think yes. If you look at the ORD shackle flip kit on Steves K5 you'll see they removed the rivets holding the original shackle bracket and replaced them with grade 8 bolts for the new bracket.
    Rene
  3. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Hey man, are you sure thats a rivet? When I replaced my springs and upgraded to the ORD shackles, it was just plain old nuts and bolts that held it on. Stock was Grade 8 and ORD sent out Grade 8 bolts, so that is the way to go.
    '73 K5
    Chevy good...Ford bad
  4. '73 K5
    1,763
    Kansas
    Well dangit. I thought you were talking about the frontend for some reason. YES they are rivets in the back and a Grade 8 bolt will be OK.
    '73 K5
  5. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Yeh, I am talking about the front end, wish I wasnt, I tried to punch the top half out and it won't budge, I guess I'll keep on banging , it beats replacing ball joints!! Thanks for the replies!
    Jim
