Best Pistons
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73 K5 Blazer, Dec 17, 2001.
  1. 73 K5 Blazer
    73 K5 Blazer 1/2 ton status
    Sep 14, 2001
    483
    Madison, MS
    I am going to rebuild my 350 and would like some information on the best pistons for my blazer. What is the different between cast, forged, and Hypereutectic? The Blazer ill be a all around truck used for off-road and street use.
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    cast = cheap
    hyperuetectic = expensive cast piston
    forged = good piston but may have more oil consuption issues when cold depending on who built it and for what application
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Cast Pistons- are what the engine usually comes with stock. They are ok for a stock engine or mild performance add ons.
    Hypereutectic.- Also used in some OE engines. They are better than cast. They wear better and give more power, reduced emissions ect. They are made up of a aluinimium alloys that contain silicon.
    Forged Pistons are usually used in high performance applications. They are kind of expensive for use a daly driver that you are not going to put heavy loads on.
    As for Pistons I like Silvolite Pistons they have always worked well for me.
    Heres some more info on pistons:<a target="_blank" href=http://www.kb-silvolite.com/page11.htm>kb-silvolite.com</a>
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Basically with pistions... you get what you pay for if you are going high performance. I like JE's the best. But for cheaper builds the new speed pro are ok among others. I'm not reall a big Keith Black fan.... but the Silver-lites are a good piston for a mild motor
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  5. michaelm
    Feb 2, 2001
    872
    pushing a heavy truck with a small motor is heavy loads
