Best place for Brake lines?
Discussion in 'The Garage' started by Bross82, Aug 14, 2006.
  1. Bross82
    Bross82 1/2 ton status
    Feb 11, 2002
    215
    Spencer, MA
    I managed to fire up the 85 blazer without any real problem with starting it yesterday after it hadn't been started for about 6 months. That seems like its all set.
    The problem I ran into was when I went to test it out and put it in drive. The brake pedal felt really spongy and then it went straight to the floorboard. I checked underneath and it looks like the line just above the front left tire split and one of the lines along the framerail split and was sprayin out fluid all over the ground. :eek1:
    So, now I'm looking into replacing them with all new extended brake lines to match the 4" suspension lift. These were the original brake lines that split.
    Does anyone know a good place to get new extended brake lines?
    Are extended lines for a 4" lift to short if I decide to do a shackle flip later on?
    Has anyone ever heard of russel performance or goodridge?
    Russel Performance
    http://www.russellperformance.com/auto/brake/b_lines_suv-gm.shtml
    Goodridge
    http://www.raceshopper.com/goodridge_brake_lines.shtml
    Thanks!
    matt
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
  3. Tabb
    Tabb ROLL TIDE! AGAIN! GMOTM Winner
    May 2, 2006
    3,566
    21
    Heart of Dixie
    I still have my stock brake lines on mine with a 4"lift, all I did was unbolt the brake hose from the hard line, bolted a L bracket on the bottom of the frame, ran the brake line through the bracket and put the clips back on. They still have some slack in them at full droop.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    We carry Crown Performance brake lines made specifically for the types of mods we do to our rigs in stock. Our front lines are 30" long and the rear drop line is 24" long. They can be used with a VERY flexy 4" lift all the way up to a stiff 10" lift.
    Here is a link to a pics of ours vs. Superlifts
    http://www.blackwidowperformance.com/ourline_theirline.jpg
    Here is a link to the GM page
    http://www.blackwidowperformance.com/chevy_gmc_brake_lines.html
    Crown Performance makes the absolute best aftermarket brake lines out there in our opinion. Several from here have bought them and love them!
  5. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    Thanks.. I might just look into a set of those.
    Just a few other things..
    Do you recommend swapping out and installing speed bleeders while i'm at it?
    is there a particular type of brake fluid that i should get?
    Thanks again! :bow:
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Speed bleeders are great if you are doing it all by yourself. If you have help, they are not necessary.
    I use the generic Napa brake fluid. Works just fine for me. :)
  7. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    ok i think i might be confused on what i might need to order..:confused:
    the lmc catalog has somethin like 8 pieces for i believe its the original kit for an 85
    you mentioned the front lines are 30" and the rear 24"s....am i missing something on lines i need to get to go across the front axle and along the frame rail?
    the line split just above the left front tire on the outside of the frame, and then along the inside across from the rear driveshaft. so it seems like i need more than just this
  8. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    is there some other line i need to order besides the pair for the front and the drop line in the rear?
    thanks!
  9. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    Hi, is there some other brake line i need to order for along the frame rail besides the extended lines mentioned above?
    Thanks! :laugh:
  10. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    If you just need the flexible lines from the frame to the calipers to compensate for the lift, then no. All you need are the 3 extended lines. The rest should remain stock.
    The lengths ours are made to pretty much ensure that you will never stress one even under full droop when wheeling.
  11. Bross82
    Feb 11, 2002
    215
    Spencer, MA
    ok, thanks. i think i was confused at first. i think its all mainly the main brake lines are what i need to replace and not so much the lines that would need to be extended. but, if i do have to go through all the trouble of replacing the main lines maybe i'll just do the extended lines now too.
    for the main brake lines, do you know of any good kits for it? is the lmc 8 piece one decent?
    Thanks again!
