best place price for case spreader?
Discussion in 'The Garage' started by sled_dog, Aug 31, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    need one for doing my 60 work.
  2. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    BIG prybars, brass punch.
  3. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I thought I'd need one when I did my 70 regear because I was not able to budge it once I pulled the carrier bearing caps. Turns out Ijust needed a longer prybar. I used a 3' prybar and a BFH to help coax it out. I thought I'd need a spreader to get it back in with the proper amount of carrier preload shims, but I was able to coax it back in again with a plastic faced hammer, when it was in far enough, I put the bearing caps on and tightened the bolts to suck it in the rest of the way. Worked ou, no prob, and I had to put it in and remove it 3 times due to unnacceptable gear patterns.
    Now wait until you have to pull the carrier bearings! /forums/images/graemlins/eek.gif
