Best place to buy gaskets, weatherstripping etc.
Discussion in 'The Garage' started by gjk5, Jun 1, 2004.
  1. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    I need some pointers, the new '72 sounds like an anti-aircraft battery while driving off-road. Every gasket and weatherstrip is eaten up so every part that could rub and knock does. The rear window was shaking back and forth a couple of inches, I thought it was gonna fall right off.
    I definitely need to replace all of the weatherstripping and gaskets on doors window etc., but was wondering if putting a poly bushing kit might help with the rattles/shakes.
    Also, as a side note, I've never owned a vehicle with a lift this one has some serious body roll and dive going on. (2.5" lift, Rancho 7000's) Is this to be expected?
  2. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    I replaced the door weatherstripping and it didnt help my doors from squeaking and popping so I finally removed them. I bought the weatherstripping from LMC, it fit well but Im not impressed with the quality of the rubber. If you're going to be doing any serious offroading I would suggest removing the rear window or the entire top. /forums/images/graemlins/thumb.gif
    I dont think any First Gens have anti-sway bars so this could be causing it to feel differently. I would check steering box bolt tightness, spring u-bolt tightness and shackle tighness. Poly body mounts are pretty stiff compared to rubber, should help body roll if your existing ones are worn out /forums/images/graemlins/thumb.gif
