Best Place to get "12V only when in reverse"?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Aug 13, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Best Place to get \"12V only when in reverse\"?
    I am wiring in my back up lights. Where is a good place to tap into a wire that will be dead when truck is on normalls but live in reverse? Looking for something up towards the fire wall. Colors would be helpful too. Thanks!
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Re: Best Place to get \"12V only when in reverse\"?
    Um.. I think you will need to setup a relay that will be ground switched energized for this.
    IIRC the backup lights work when the trans makes a ground when it is in reverse. Hence the backup lights are already gettting 12V positive. The ground just completes the circuit.
    Have FUN!
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you could use a relay and tap into your reverse switch on your steering colum. i would recomend some type of relay if you are gonna be running something that draws a lot of amperage, it'll keep you from replacing your reverse switch, it can be a pain. not sure what color it is but you can look toward the back of your steering column(by the firewall), you shouls see some wires going to it(on the column). I think the neutral safty switch and the reverse switch are in that area, not sure on your model year. hope others will add...
    ARQ.
  4. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    They are wired in with a relay. Now I just need to find the right wire.
  5. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Just tap off the reverse light lead. What brand relay are you using? I got some from West Marine that have a weather cap on them. You arent really drawing a too much current to trigger the relay. Just remember to run equal ga. wire from the batt. to relay and relay to lights. I found that if you just remove one of your rear light housings and make the tap there( right where the bulb for the reverse light socket is) it will keep more road grime off and some water.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    on mine it is a bonded pair of lt grn and drk grn that comes throughthe firewall from the manual tranny
    go check a wiring diagram
  7. gpd4
    gpd4 Registered Member
    Jun 25, 2001
    55
    St. Louis, MO
    I did it the easy way. Since the plug from the 700R4 wouldn't fit in the hole on the TH350, I just mounted some tractor lights on the rear bumper and ran a toggle switch up to the dash. If I want lights on the road behind me I just turn them on...Also helps with loading boats and trailers in the dark.
    18 short days 'till dove season...
